path: root/include/configs/at91sam9261ek.h
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-23configs: at91: Adjust CONFIG_ENV_OFFSET to match sama5 addressNicolas Ferre
In order to have a single ENV_OFFSET to manage, use the same as the sama5 one. This address matches our NAND flash map available at: http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> [eugen.hristev@microchip.com: rework on latest version of u-boot] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-04board: at91sam9261ek: Update to support DT and DMWenyou.Yang@microchip.com
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-25Convert CONFIG_ENV_IS_IN_DATAFLASH to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_DATAFLASH Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-11ARM: atmel: boards: use default CONFIG_SYS_PBSIZEBo Shen
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-11-17spi, atmel: move CONFIG_SYS_SPI_WRITE_TOUT into common headerHeiko Schocher
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h and define a default value. Delete this define in the board config files, where it is possible (all boards use currently the same value). Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17ARM: at91 series: convert to generic boardBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-03-12ARM: at91: change nand flash tableBo Shen
Change nand flash partition table according to www.at91.com/linux4sam more information: http://www.at91.com/linux4sam/bin/view/Linux4SAM/GettingStarted#Linux4SAM_NandFlash_demo_Memory Signed-off-by: Bo Shen <voice.shen@atmel.com> [minor commit message changes] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-17Atmel: sam9g10/9m10/9x5: Add support to boot DT kernelBo Shen
The mainline linux kernel is moving to flatten device tree support Add the CONFIG_OF_LIBFDT option to support booting DT linux kernel Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm: sam9g10/sam9m10g45: remove CONFIG_ARCH_CPU_INITBo Shen
Remove CONFIG_ARCH_CPU_INIT for at91sam9g10ek and at91sam9m10g45ek Signed-off-by: Bo Shen <voice.shen@atmel.com> [rebase on TOT] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-07-07AT91SAM9*: Change kernel address in dataflash to match u-boot's sizeAlexandre Belloni
On at91sam platforms, u-boot grew larger than the allocated size in dataflash, the layout was: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00042000 fs 0x00252000 u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 = 0x39C00 bytes anymore. Now, the layout is: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00084000 fs 0x00294000 Signed-off-by: Alexandre Belloni <alexandre.belloni@piout.net> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12add a new AT91 GPIO driverJens Scharsig
* add a real AT91 GPIO driver instead of header inline code * resolve the mixing of port and pins * change board config files to use new driver * add macros to gpio to realize backward compatibility Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
