This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE
into the console and hitting enter afterwards, causes a hang in the
system because CONFIG_SYS_PBSIZE is not capable of storing the extra
characters of the error message:
"Unknown command '' - try 'help'".
Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h
to solve this problem.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h
and define a default value. Delete this define in the board
config files, where it is possible (all boards use currently
the same value).
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
board/compulab/cm_t35/Makefile
board/corscience/tricorder/Makefile
board/ppcag/bg0900/Makefile
drivers/bootcount/Makefile
include/configs/omap4_common.h
include/configs/pdnb3.h
Makefile conflicts are due to additions/removals of
object files on the ARM branch vs KBuild introduction
on the main branch. Resolution consists in adjusting
the list of object files in the main branch version.
This also applies to two files which are not listed
as conflicting but had to be modified:
board/compulab/common/Makefile
board/udoo/Makefile
include/configs/omap4_common.h conflicts are due to
the OMAP4 conversion to ti_armv7_common.h on the ARM
side, and CONFIG_SYS_HZ removal on the main side.
Resolution is to convert as this icludes removal of
CONFIG_SYS_HZ.
include/configs/pdnb3.h is due to a removal on ARM side.
Trivial resolution is to remove the file.
Note: 'git show' will also list two files just because
they are new:
include/configs/am335x_igep0033.h
include/configs/omap3_igep00x0.h
Get rid of too many ifdeffery in usb ohci driver
Add following two configuration for USB clock selecting
- CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock
- CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
[trini: Fixup common/cmd_io.c]
Change nand flash partition table according to www.at91.com/linux4sam
more information: http://www.at91.com/linux4sam/bin/view/Linux4SAM/GettingStarted#Linux4SAM_NandFlash_demo_Memory
[minor commit message changes]
The mainline linux kernel is moving to flatten device tree support
Add the CONFIG_OF_LIBFDT option to support booting DT linux kernel
Remove CONFIG_ARCH_CPU_INIT for at91sam9g10ek and at91sam9m10g45ek
[rebase on TOT]
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
On at91sam platforms, u-boot grew larger than the allocated size in
dataflash, the layout was:
bootstrap 0x00000000
ubootenv 0x00004200
uboot 0x00008400
kernel 0x00042000
fs 0x00252000
u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 =
0x39C00 bytes anymore.
Now, the layout is:
ubootenv 0x00004200
uboot 0x00008400
kernel 0x00084000
fs 0x00294000
Signed-off-by: Alexandre Belloni <alexandre.belloni@piout.net>
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
Change my old email address which is no longer valid.
Signed-off-by: Stelian Pop <stelian@popies.net>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Fix board part of AT91SAM9261-EK according to the new scheme
Signed-off-by: Hong Xu <hong.xu@atmel.com>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
For ARM systems, before ELF relocation was introduced,
CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the
U-Boot image from whereever it was loaded to it's link address
(CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation
was performed at all, it was just a memcpy().
With ELF relocation, this does not work like that any more, and
related boards need to be fixed anyway. So don't keep this relict any
longer.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
* add a real AT91 GPIO driver instead of header inline code
* resolve the mixing of port and pins
* change board config files to use new driver
* add macros to gpio to realize backward compatibility
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
The name of the atmel nand driver in the kernel changed from at91_nand
to atmel_nand back in June 2008, but the at91-based boards config files
still refer to at91_nand. This patch updates them with the new name
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
A large number of boards (all AT91 based) duplicated the ROUND()
macro in their board specific config files. Add the definition to
include/common.h and clean up the board config files.
Commit 8d2effea added a warning for configurations that use NAND
without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but
failed to fix the affected boards.
This patch covers the non-PPC boards that were missed in the previous
patch (commit 170c1972).
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a
faster clock speed: 266/133MHz.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
All drivers need to be converted to CONFIG_NET_MULTI.
This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Some boards do not have SROM support for the DM9000 network adapter.
Instead of listing these board names in the driver code, make this
option configurable from the board config file.
It also removes a build warning for the at91sam9261ek board:
'dm9000x.c:545: warning: 'read_srom_word' defined but not used'
And it repaires the trizepsiv board build which was broken around the
same routines
The timer has been rewrote with a precision at ~0,18%
Tested-by: Sergey Lapin <slapin@ossfans.org>
Tested-by: Eric BENARD <ebenard@free.fr>
calculate dynamically the clock rate and pllb setting for usb
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Rather than forcing people to define a custom "LITTLEENDIAN", just use the
__LITTLE_ENDIAN one from the Linux byteorder headers that every arch is
already setting up.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This patch adds the possiblity to choose the media where the environment will
be located. This allow to choose this fundamental configuration without editing
config files.
Documentation file added.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Stelian Pop <stelian@popies.net>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
At least some (old ?) versions of the AT91Bootstrap do not set up the
PLLB correctly to 48 MHz in order to make USB host function correctly.
This patch sets up the PLLB to the same values Linux uses, and makes USB
work ok on the following CPUs:
- AT91CAP9
- AT91SAM9260
- AT91SAM9263
This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all
the relevant AT91CAP9/AT91SAM9 atmel boards.
Introduce AT91_CPU_CLOCK and use it for displaying the CPU
speed in the LCD driver.
Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the
corresponding board clocks.
