path: root/include/configs/at91sam9260ek.h
2009-08-18Update the mtd driver name in bootargs for at91-based boardsAlbin Tonnerre
The name of the atmel nand driver in the kernel changed from at91_nand to atmel_nand back in June 2008, but the at91-based boards config files still refer to at91_nand. This patch updates them with the new name Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-22AT91: factor out ROUND() macroWolfgang Denk
A large number of boards (all AT91 based) duplicated the ROUND() macro in their board specific config files. Add the definition to include/common.h and clean up the board config files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12at91: move cpu name define to arm/arch/ cpu headerJean-Christophe PLAGNIOL-VILLARD
2009-04-16at91sam9/at91cap: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
The timer has been rewrote with a precision at ~0,18% Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Tested-by: Sergey Lapin <slapin@ossfans.org> Tested-by: Eric BENARD <ebenard@free.fr>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91: move dataflash spi driver to drivers/spiJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common led management to cpuJean-Christophe PLAGNIOL-VILLARD
2009-01-28usb.h: use standard __LITTLE_ENDIAN from Linux headersMike Frysinger
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06at91: Choose environment variables location within make config targetNicolas Ferre
This patch adds the possiblity to choose the media where the environment will be located. This allow to choose this fundamental configuration without editing config files. Documentation file added. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Stelian Pop <stelian@popies.net> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-21AT91: Enable PLLB for USBStelian Pop
At least some (old ?) versions of the AT91Bootstrap do not set up the PLLB correctly to 48 MHz in order to make USB host function correctly. This patch sets up the PLLB to the same values Linux uses, and makes USB work ok on the following CPUs: - AT91CAP9 - AT91SAM9260 - AT91SAM9263 This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all the relevant AT91CAP9/AT91SAM9 atmel boards. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-05-10AT91: Cleanup unused config header file definitions.Stelian Pop
CONFIG_ENV_OVERWRITE is commented out in the config header files, so let's cleanup the files by removing the whole definition. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Fix dataflash offsets in CONFIG_BOOTCOMMANDStelian Pop
This patch fixes the dataflash offsets used in CONFIG_BOOTCOMMAND in order to cope with the changes in DataFlash partitionning scheme (cset c3a60cb3). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Normalize BOOTARGSStelian Pop
This patch adapts CONFIG_BOOTARGS to the chosen boot method (boot from DataFlash or from NAND), and gives to Linux a fully specified mtdparts variable. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Normalize SPI timingsStelian Pop
This patch changes the SPI timings to closely match the ones used by the Linux kernel and the Atmel's own bootstrap project. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Handle 8 or 16 bit NANDStelian Pop
The Atmel boards can handle 8 or 16 bit NAND memories. This patch makes the support configurable in the board config header file (CFG_NAND_DBW_8 or CFG_NAND_DBW_16). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-08Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
