path: root/include/configs/at91sam9260ek.h
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06at91: Choose environment variables location within make config targetNicolas Ferre
This patch adds the possiblity to choose the media where the environment will be located. This allow to choose this fundamental configuration without editing config files. Documentation file added. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Stelian Pop <stelian@popies.net> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-21AT91: Enable PLLB for USBStelian Pop
At least some (old ?) versions of the AT91Bootstrap do not set up the PLLB correctly to 48 MHz in order to make USB host function correctly. This patch sets up the PLLB to the same values Linux uses, and makes USB work ok on the following CPUs: - AT91CAP9 - AT91SAM9260 - AT91SAM9263 This patch also defines CONFIG_USB_STORAGE and CONFIG_CMD_FAT for all the relevant AT91CAP9/AT91SAM9 atmel boards. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-09-10rename CFG_ENV_IS_IN_NAND in CONFIG_ENV_IS_IN_NANDJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-05-10AT91: Cleanup unused config header file definitions.Stelian Pop
CONFIG_ENV_OVERWRITE is commented out in the config header files, so let's cleanup the files by removing the whole definition. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Fix dataflash offsets in CONFIG_BOOTCOMMANDStelian Pop
This patch fixes the dataflash offsets used in CONFIG_BOOTCOMMAND in order to cope with the changes in DataFlash partitionning scheme (cset c3a60cb3). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Normalize BOOTARGSStelian Pop
This patch adapts CONFIG_BOOTARGS to the chosen boot method (boot from DataFlash or from NAND), and gives to Linux a fully specified mtdparts variable. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Normalize SPI timingsStelian Pop
This patch changes the SPI timings to closely match the ones used by the Linux kernel and the Atmel's own bootstrap project. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Handle 8 or 16 bit NANDStelian Pop
The Atmel boards can handle 8 or 16 bit NAND memories. This patch makes the support configurable in the board config header file (CFG_NAND_DBW_8 or CFG_NAND_DBW_16). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-08Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
