path: root/include/configs/at91rm9200ek.h
2018-03-09ARM: Drop unreferenced CONFIG_* defines named after SoCsTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_ARM926EJS CONFIG_CPUAT91 CONFIG_EXYNOS5800 CONFIG_SYS_CORTEX_R4 Most of them are config symbols named after the respective SoCs which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-17ARM: at91 series: convert to generic boardBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-03-12arm: at91/configs: add bootz to configurationNicolas Ferre
Support to boot zImage Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> [Add bootz for at91rm9200, at91sam9263, at91sam9rl] Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-12arm: at91/configs: add libfdt to configurationNicolas Ferre
support to boot device tree Linux kernel Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> [Add libftd for at91rm9200, at91sam9263, at91sam9rl] Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-07-04at91rm9200ek: use atmel_usartAndreas Bießmann
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2010-12-07arm920t/at91/timer: replace bss variables by gdAndreas Bießmann
Reuse the gd->tbl value for timestamp and add gd->lastinc for lastinc bss values in arm920t/at91/timer driver. The usage of bss values in driver before initialisation of bss is forbidden. In that special case some data in .rel.dyn gets corrupted by the arm920t/at91/timer driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-07at91rm9200ek: add configure target for RAM bootAndreas Bießmann
This patch also removes now unnecessary config.mk in board directory and make usage of new features in boards.cfg. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-07at91rm9200ek: fix SDRAM initialistation valuesAndreas Bießmann
2010-10-19at91rm9200ek: enbable USB supportAndreas Bießmann
This patch enables USB for at91rm9200ek board. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19at91rm9200ek: convert to at91Andreas Bießmann
This patch removes some functionality from at91rm9200ek board but the remaining functionality does now work with newer at91 code and arm-relocation. Currently missing features are: - dataflash booting (due to missing HW for testing) - MMC/SD-Card - first stage bootloader support is completely removed (not needed for NOR) Cause this board was (some days ago) reference for all at91rm9200 based boards this should be a good starting point to convert all remaining at91rm9200 borads to at91 code. Aside from that this is a good base to get some drivers between at91sam/at91rm/avr32 merged. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-03rm9200 lowevel_init: don't touch reserved/readonly registersDavid Brownell
For some reason the AT91rm9200 lowlevel init writes to a bunch of reserved or read-only addresses. All the boards seem to define the value-to-be-written values as zero ... but they shouldn't actually be writing *anything* there. No documented erratum justifies these accesses. It looks like maybe some pre-release BDI-2000 setup code has been carried along by cargo cult programming since at least late 2004 (per GIT history). Here's a patch disabling what seems to be bogosity. Tested on a csb337; there were no behavioral changes. Signed-off-by: David Brownell <david-b@pacbell.net> on RM9200ek Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-22AT91: factor out ROUND() macroWolfgang Denk
A large number of boards (all AT91 based) duplicated the ROUND() macro in their board specific config files. Add the definition to include/common.h and clean up the board config files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04Add support for the AT91RM9200EK Board.Ulf Samuelsson
The AT91RM9200-EK Evaluation Board supports the AT91RM9200 ARM9-based 32-bit RISC microcontroller and enables real-time code development and evaluation. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507 with - NOR (cfi driver) - DataFlash - USB OHCI - Net - I2C (hard) Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
