path: root/include/configs/at91rm9200dk.h
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-02-12add new CONFIG_AT91_LEGACYJens Scharsig
* add's the new temporary CONFIG_AT91_LEGACY to all board configs This will need for backward compatiblity, while change the SoC access to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated SoC is used. Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-03rm9200 lowevel_init: don't touch reserved/readonly registersDavid Brownell
For some reason the AT91rm9200 lowlevel init writes to a bunch of reserved or read-only addresses. All the boards seem to define the value-to-be-written values as zero ... but they shouldn't actually be writing *anything* there. No documented erratum justifies these accesses. It looks like maybe some pre-release BDI-2000 setup code has been carried along by cargo cult programming since at least late 2004 (per GIT history). Here's a patch disabling what seems to be bogosity. Tested on a csb337; there were no behavioral changes. Signed-off-by: David Brownell <david-b@pacbell.net> on RM9200ek Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-06at91rm9200: rename lowlevel init value to CONFIG_SYS_Jean-Christophe PLAGNIOL-VILLARD
2008-12-02at91rm9200dk: Fix typoJean-Christophe PLAGNIOL-VILLARD
2008-11-24at91rm9200: fix broken boot from nor flashJens Scharsig
This patch fix the broken boot from NOR Flash on AT91RM9200 boards, if CONFIG_AT91RM9200 is defined and nor preloader is used. Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2008-09-10rename CFG_ENV_IS_IN_DATAFLASH in CONFIG_ENV_IS_IN_DATAFLASHJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-31at91rm9200dk, csb637: fix NAND related build problemsWolfgang Denk
Tried fixing NAND support for the at91rm9200dk board; untested. Disabled NAND support in the csb637 board config file. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-30use correct at91rm9200 register nameDavid Brownell
This fixes a naming bug for at91rm9200 lowlevel init code: NOR boot flash is on chipselect 0, not chipselect 2. This makes code use the register name from chip datasheets. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2008-02-04ARM: AT91RM9200 based boards config cleanupLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Remove nowhere used struct bd_info_ext, remove trailing whitespaces, fix indentation.
2008-02-04ARM: Fix at91rm9200dk base addressLadislav Michl
Somewhere during development of U-Boot-1.1.3 CONFIG_BOOTBINFUNC was renamed into CONFIG_INIT_CRITICAL which was 04 Apr 2005 replaced with CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT. However CONFIG_SKIP_LOWLEVEL_INIT has oposite meaning to CONFIG_BOOTBINFUNC, so fix configuration to reflect this fact. I'm sending this patch 4th (!) time in hope it produces at least some reaction. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Fix at91rm9200dk base and environment address.
2007-08-14Add MACH_TYPE records for several AT91 boards.Peter Pearse
Merge to two at45.c files into a common file, split to at45.c and spi.c Fix spelling error in DM9161 PHY Support. Initialize at91rm9200 board (and set LED). Add PIO control for at91rm9200dk LEDs and Mux. Change dataflash partition boundaries to be compatible with Linux 2.6. Signed-off-by: Peter Pearse <peter.pearse@arm.com> Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2007-07-10include/configs/[a-e]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various a* named board config files.Jon Loeliger
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-04-20get rid of obsolete CFG_AT91C_BRGR_DIVISOR definitionwdenk
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-03-31Patch by Steven Scholz, 13 Dec 2004:wdenk
Remove duplicated code by merging memsetup.S files for at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-10-11Fix CFG_HZ problems on AT91RM9200 systemswdenk
[Remember: CFG_HZ should be 1000 on ALL systems!]
2004-09-21Patch by Gary Jennejohn, 09 Sep 2004:wdenk
allow to use USART1 as console port on at91rm9200dk boards
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-03-15* Patch by Steven Scholz, 27 Feb 2004:LABEL_2004_03_16_2330wdenk
- Adding get_ticks() and get_tbclk() for AT91RM9200 - Many white space fixes in cpu/at91rm9200/interrupts.c * Patches by Steven Scholz, 20 Feb 2004: some cleanup in AT91RM9200 related code
2004-02-24* Patch by Andrea Scian, 17 Feb 2004:wdenk
Add support for S3C44B0 processor and DAVE B2 board * Patch by Steven Scholz, 20 Feb 2004: - Add support for MII commands on AT91RM9200 boards - some cleanup in AT91RM9200 ethernet code
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
