path: root/include/configs/at91-sama5_common.h
2018-05-23configs: at91: sama5_common: Adjust CONFIG_ENV_OFFSET to match block alignmentNicolas Ferre
Fix the unaligned environment address. This address matches our NAND flash map available at: http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> [eugen.hristev@microchip.com: rework on latest version of u-boot] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-14ARM: at91: Remove hardware.h included in configsWenyou Yang
As said in READRE.kconfig, include/configs/*.h will be removed after all options are switched to Kconfig. As the first step, remove the follow line from include/configs/*.h. #include <asm/hardware.h> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_FAT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-13configs: at91-sama5_common: fix for CONFIG_AT91_GPIOWenyou Yang
Add #ifndef CONFIG_DM_GPIO for CONFIG_AT91_GPIO define to avoid the redefine compilation error. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-10-28AT91: Correct misspelling of "redundent" in partition namesRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-01-31armv7: add cacheline sizes where missingAlbert ARIBAUD
Some armv7 targets are missing a cache line size declaration. In preparation for "arm: cache: Implement cache range check for v7" patch, add these declarations with the appropriate value for the target's SoC or CPU. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-01ARM: at91: sama5: change the environment address to 0x6000Josh Wu
As sama5 board has 32k sram size, so the at91bootstrap and spl for sama5 boards is bigger than 16k (0x4000). That will overlap the U-Boot environment. So I move environment to 0x6000. And reduce its size as well. Following shows the size of the spl binaries (v2015.04 vs v2015.07): % ls v2015.04/*spi*spl.bin -l | awk '{print $5,$(NF)}' 15540 v2015.04/at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin 15704 v2015.04/at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin 16064 v2015.04/sama5d3xek_spiflash_defconfig_u-boot-spl.bin 16304 v2015.04/sama5d4ek_spiflash_defconfig_u-boot-spl.bin 16304 v2015.04/sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin % ls v2015.07/*spi*spl.bin -l | awk '{print $5,$(NF)}' 16136 v2015.07/at91sam9n12ek_spiflash_defconfig_u-boot-spl.bin 16300 v2015.07/at91sam9x5ek_spiflash_defconfig_u-boot-spl.bin 16664 v2015.07/sama5d3xek_spiflash_defconfig_u-boot-spl.bin 16904 v2015.07/sama5d4ek_spiflash_defconfig_u-boot-spl.bin 16904 v2015.07/sama5d4_xplained_spiflash_defconfig_u-boot-spl.bin The gcc version is: gcc 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1) Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Bo Shen <voice.shen@gmail.com>
2015-10-01ARM: at91: sama5: add support for CONFIG_ENV_IS_IN_MMCJosh Wu
If defined CONFIG_ENV_IS_IN_MMC, then u-boot environment is saved in mmc's raw sectors. Otherwise, u-boot environment is saved as a file: uboot.env. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Bo Shen <voice.shen@gmail.com>
2015-09-11ARM: atmel: boards: use default CONFIG_SYS_PBSIZEBo Shen
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5: update the spi flash mappingWu, Josh
Also move the spi flash configurations to the at91-sama5_common.h. Current at91 zImage size is about 3.3M, the old mapping is not suitable. So update the spi flash map as following: 0x0 ~ 0x004000: at91bootstrap(16k) 0x04000 ~ 0x008000: u-boot env(16k) 0x08000 ~ 0x060000: u-boot(352k) 0x60000 ~ 0x06c000: dtb (48k) 0x6c000 ~ 0x400000: kernel (3M+592k) In AT91Bootstrap, the U-Boot in spi flash also update to 0x8000, refer to following commit in AT91Bootstrap: 3e91e54 Kconfig: fix spi flash address So also update SPL's u-boot load address to 0x8000 in spi flash. Signed-off-by: Josh Wu <josh.wu@atmel.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-21ARM: at91: sama5: move the nandflash env config to at91-sama5_common.hWu, Josh
As all sama5 nandflash env configurations are same, so move them to at91-sama5_common.h. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5d3xek: use a $dtb_name to load dtbWu, Josh
Since sama5d3xek boards has different type of dtb blobs, so we need to detect the cpu type in runtime. So we add a new variable $dtb_name. if $dtb_name is not defined, we just use at91-${board_name}.dtb as the $dtb_name. Otherwise, we will just load the dtb with $dtb_name. For sama5d3xek, we will detect cpu type and make up $dtb_name in runtime. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-08-21ARM: at91: sama5: move the sd/mmc env config to at91-sama5_common.hWu, Josh
As almost all sama5 sd/mmc env configurations are same, so move them to at91-sama5_common.h. Also define CONFIG_ENV_VARS_UBOOT_CONFIG to have the varaible: $board_name. Then we can use 'at91-${board_name}.dtb' as the dtb name. TODO: since sama5d3xek has different dtb name, we need to some extra stuff to make it work on sama5d3xek boards. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-05-13ARM: at91: trival: fix typo for the nand partition nameWu, Josh
We should use 'env' to present environment instead of 'evn' Signed-off-by: Josh Wu <josh.wu@atmel.com>
2015-04-01ARM: at91: sama5: move the common part of configurations to at91-sama5_common.hWu, Josh
Create a new configuration file: at91-sama5_common.h. Which includes the configurations that reused by all SAMA5 chips. at91-sama5_common.h includes: - hw macros (clock, text_base and etc.) - default commands. - BOOTARGS - U-Boot common configs. NOTE: NOR flash definition should be put before including the common header. For sama5d3-xplained: - add CMD_SETEXPR For sama5d3xek: - add CMD_SETEXPR - change CONFIG_SYS_MALLOC_LEN to (4*1024*1024) Signed-off-by: Josh Wu <josh.wu@atmel.com>
