A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Add architecture-specific u-boot.lds and remove all board-specific
u-boot.lds.
All the .text customization that was board-specific have been
moved inside the related include/configs, inside a
LDS_BOARD_TEXT define.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
This commit intends to stop grepping CPU type in
arch/m68k/cpu/mcf532x/config.mk.
Move the CPU type config options from include/configs/*.h
to arch/m68k/Kconfig and refactor the CPU flags select in
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Angelo Dureghello <angelo@sysam.it>
Guard the LOADMK functionality with config to provide
an option to enable or disable it.
Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
- added to soft_i2c driver new multibus/multiadpater support
Fix up the rest of implementations of __stringify().
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
When planning for more generalization and Makefile cleanup it became
obvious that the introduction of a separate CONFIG_MK_ name space for
config options that were set through scripting in the Makefile was
not a good idea.
Originally the idea was to provide a script-free approach to supply
configuration options - there was no real need for a separate name
space. But when we now convert the existing Makefile entries to make
use of this approach, it would mean that we have to touch a large
number of board config files and add #ifdef / #define sequences to
"convert" from the CONFIG_MK_ to the CONFIG_ name space.
It seems much cleaner to get rid of this somewhat arbitrary _MK
string now for the few boards that actually use it.
The CF will call cache functions in lib_m68/cache.c and the
cache settings are defined in platform configuration file.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
