This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
them from include/configs.
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed
from the configs.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless.
Besides, it is never referenced.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Rmobile board select menu to rmobile/Kconfig.
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="rmobile").
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Add CONFIG_SYS_GENERIC_BOARD to use common/board_*.c for armadillo800eva.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CONFIG_SYS_GBL_DATA_SIZE is not used any more.
The size of struct "global_data" is automatically calculated
by asm-offsets. (See lib/asm-offsets.c)
GENERATED_GBL_DATA_SIZE should be used instead of
CONFIG_SYS_GBL_DATA_SIZE.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to
CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to
CONFIG_SH_TMU_CLK_FREQ,
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Albert Aribaud <albert.u.boot@aribaud.net>
[trini: Fixup common/cmd_io.c]
armadillo-800eva needs this config.
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM,
Ethernet, and more.
This patch supports the following functions:
- 512MB DDR3-SDRAM
- Serial console (SCIF)
- Ethernet MAC(MII) & PHY(SMSC)
Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com>
