path: root/include/configs/armadillo-800eva.h
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-04-30Kconfig: Drop CONFIG_CMD_DFLSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-16Kconfig: Move USE_ARCH_MEMCPY/MEMSET to KconfigFabio Estevam
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig. Make it "default y" for the ARMv7 architecture and make it depend on !ARM64 && !SPL. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2014-11-20ARM: remove CONFIG_ARMV7 definesMasahiro Yamada
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless. Besides, it is never referenced. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-05-21arm: rmobile: armadillo800eva: Enable CONFIG_SYS_GENERIC_BOARDNobuhiro Iwamatsu
Add CONFIG_SYS_GENERIC_BOARD to use common/board_*.c for armadillo800eva. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-22arm: rmobile: armadillo-800eva: Change clock definition of SCIF and TMUNobuhiro Iwamatsu
This changes clock definition of SCIF from CONFIG_SYS_CLK_FREQ to CONFIG_SH_SCIF_CLK_FREQ, and clock definition of TMU from CONFIG_SYS_CLK_FREQ to CONFIG_SH_TMU_CLK_FREQ, Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2012-10-03rmobile: armadillo-800eva: Remove CONFIG_SYS_NO_L2CACHENobuhiro Iwamatsu
armadillo-800eva needs this config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03rmobile: armadillo-800eva: Add Support NFS and BOOTZ commandNobuhiro Iwamatsu
2012-10-03rmobile: armadillo-800eva: Add Support CONFIG_OF_LIBFDTNobuhiro Iwamatsu
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
