path: root/include/configs/arcangel4.h
2016-08-05arc: Rename ARCangel4 board to nSIMAlexey Brodkin
ARCangel was one of the main development boards back in the day but now it's gone and replaced by other boards like ARC SDP. But we also used to have simulation platform very similar to ARCangel4 in terms of CPU settings as well as basic IO like UART. Even though ARCangel4 is long gone now we have a replacement for simulation which is a plain or stand-alone nSIM and Free nSIM. Note Free nSIM is available for download here: https://www.synopsys.com/cgi-bin/dwarcnsim/req1.cgi And while at it: * Finally switch hex numerical values in nsim.h to defines from include/linux/sizes.h * Add defconfigs with ARC HS38 cores * Recreated all defconfigs with savedefconfig Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-02-09arc: move SYS_MONITOR_BASE setup in KonfigAlexey Brodkin
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig. This makes "include/configs/*.h" cleaner and more flexible. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: hard-code CONFIG_ARCH_EARLY_INIT_R in asm/config.hAlexey Brodkin
Common arch_early_init_r() is used in "arc/lib/cpu.c" for all ARC boards so there's no sense in separate per-board definitions. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: get rid of useless CONFIG_SKIP_LOWLEVEL_INITAlexey Brodkin
Currently there's nothing related to really low-level init on ARC so CONFIG_SKIP_LOWLEVEL_INIT definition makes no sense. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: hard-code CONFIG_SYS_GENERIC_BOARD into asm/config.hAlexey Brodkin
There're no other options for ARC except "generic board" so ther's no point to define CONFIG_SYS_GENERIC_BOARD per board. We now have it set fo all ARC boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: select cache settings via menuconfigAlexey Brodkin
This change allows to keep board description clean and minimalistic. This is especially helpful if one board may house different CPUs with different features. It is applicable to both FPGA-based boards or those that have CPUs mounted on interchnagable daughter-boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: add more flavours of ARC700 series CPUAlexey Brodkin
Now we may select a particular version of ARC700: * ARC750D or * ARC770D It allows more flexible (or more fine tuned) configuration of U-Boot. Before that change we relied on minimal configuration but now we may use specific features of each CPU. Moreover allows us to escape manual selection of options that exist in both CPUs but may have say different version like MMUv2 in ARC750D vs MMUv3 in ARC770D. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09arc: remove CPU hard-coded selection from board description in include/configsAlexey Brodkin
With switch to Kconfig we only need very board-specific descriptions in include/configs. CPU selection is performed with either defconfig or manually via menuconfig. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-01-14Kconfig: move CONFIG_SYS_CLK_FREQ to KconfigAlexey Brodkin
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig" instead of "include/configs/xxx.h" because then header will be reusable across boards with different CPU clocks. Also this nice to have an ability for end user to tune this value himself via "menuconfig". For now I'm only applying this change to all ARC configs because otherwise scope of change will be huge. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Hans de Goede <hdegoede@redhat.com> cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2014-02-07arc: add Arcangel4 board supportAlexey Brodkin
Arcangel4 is a FPGA-based development board that is used for prototyping and verificationof of both ARC hardware (CPUs) and software running upon CPU. This board avaialble in 2 flavours: * Little-endian (arcangel4) * Big-endian (arcangel4-be) Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
