path: root/include/configs/apollon.h
2008-11-19ARM: Add Apollon UBI supportKyungmin Park
To enable UBI on Apollon you need to uncomment the CONFIG_SYS_USE_UBI macro. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-10rename CFG_ENV_IS_IN_ONENAND in CONFIG_ENV_IS_IN_ONENANDJean-Christophe PLAGNIOL-VILLARD
2008-07-31Remove unused I2C at apollon boardKyungmin Park
There are no I2C devices on this board. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-04-13Add apollon board MAINTAINERS entryKyungmin Park
2008-01-09Coding Style cleanup, update CHANGELOGWolfgang Denk
2007-11-15Remove warnings re CONFIG_EXTRA_ENV_SETTINGSPeter Pearse
Remove warnings re onenand_read() & write()
2007-11-09Add apollon board supportPeter Pearse
