path: root/include/configs/apalis-tk1.h
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-30power: Convert CONFIG_PMIC_AS3722 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_PMIC_AS3722 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30power: Rename CONFIG_AS3722_POWER to CONFIG_PMIC_AS3722Simon Glass
Before converting this to Kconfig, rename it to match the other PMICs. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-01arm: tegra: initial support for apalis tk1Marcel Ziswiler
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards. The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot, environment storage and Toradex factory config block - Gigabit Ethernet - MMC/SD cards (both MMC1 as well as SD1 slot) - USB client/host (dual role OTG port as client e.g. for DFU/UMS or host, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
