Modify configuration for Tezi:
- Use distroboot by default
- Boot from external SD cards by default
- Disable USB PID from config block (otherwise recovery mode download
in U-Boot stage fails)
Change usb_port_owner_info to 3 in defargs to allow for USB 3.0
SuperSpeed functionality on USBO1 in host mode.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Disabling ASPM fixes incompatibilities with some PCIe cards
It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Finish the work started by the following commit:
apalis/colibri: fix and synchronize mount options
6ed47e0f143df1c80426edb3b705c87c443c27f7
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Trying to boot from an ext4 rootfs fails due to us defaulting to ext3.
While the downstream T20/T30 L4T kernel has issues with ext4 later TK1
L4T should work just fine with it. Hence enable ext4 for sdboot and
usbboot on TK1.
Rather than relying on our separate proprietary storage media dependent
boot commands use regular distro boot as a fall back.
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
