The rest of the unmigrated CONFIG symbols in the CONFIG_SYS namespace do
not easily transition to Kconfig. In many cases they likely should come
from the device tree instead. Move these out of CONFIG namespace and in
to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_SDRAM
namespace do not easily transition to Kconfig. In many cases they likely
should come from the device tree instead. Move these out of CONFIG
namespace and in to CFG namespace.
The rest of the unmigrated CONFIG symbols in the CONFIG_SYS_NS16550
CONFIG_SYS_MIPS_TIMER_REQ
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Resolve all uses of CONFIG_SYS_MHZ with the currently defined value.
Remove code which depends on CONFIG_SYS_MHZ but where no board configs
actually use that code.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_BOOTPARAMS_LEN
CONFIG_SYS_MONITOR_BASE
Note that for how this is re-used on some PowePC platforms, we introduce
CONFIG_SPL_SYS_MONITOR_BASE and CONFIG_TPL_SYS_MONITOR_BASE and use the
CONFIG_VAL macro to get the correct value at build time, in the code.
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
As part of this, we use Kconfig to provide the defaults now that were
done in include/spi_flash.h. We also in some cases change from using
CONFIG_ENV_SPI_FOO to CONFIG_SF_DEFAULT_FOO as those were the values in
use anyhow as ENV was not enabled.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_HZ
A number of platforms are still defining CONFIG_SYS_BAUDRATE_TABLE to
the fallback default of "{ 9600, 19200, 38400, 57600, 115200 }", but
with varying whitespace, or were introduced after the default fallback
was added. Use the default table here.
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
QCA9563 is CPU used on AP152 board :
Clock speed : 750 MHz ,
Arch : Mips 74Kc,
Eth : SGMII interface,
MIMO config : 3 * 3 450M,
2 * USB 2.0,
Signed-off-by: Rosy Song <rosysong@rosinson.com>
Changes for v2:
- coding style cleanup
- remove ununsed flash chip in defconfig
- enable automatic icache / dcache size in defconfig
Changes for v3:
- add detailed information for qca956x in commit message
Changes for v4:
- remove pre-configured network settings in ap152.h
Changes for v5:
