Change bootm flash address and mtd partition table for 8MB flash profile.
Signed-off-by: Wills Wang <wills.wang@live.com>
Move details of the L1 cache line sizes & total sizes into Kconfig,
defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is
introduced to allow platforms to select auto-detection of cache sizes,
and it defaults to being enabled if none of the cache sizes are set by
the configuration (ie. sizes are all the default 0), and code is
adjusted to #ifdef on that rather than on the definition of the sizes
(which will always be defined even if 0).
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board
Kconfig files matching what was present in their config headers. This
will make it cleaner to conditionalise the value for Malta based on 32
vs 64 bit builds.
This patch add board-level code and base DT for AP121.
[updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
