path: root/include/configs/amcc-common.h
2016-02-29amcc-common.h: Disable CONFIG_SYS_LONGHELPTom Rini
There are a number of AMCC platforms which are close to, or with some toolchains exceeding, the size constraints. Disable CONFIG_SYS_LONGHELP to get us room to build with again. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-10kconfig: Move REGEX to KconfigJoe Hershberger
Having this as a Kconfig allows it to be a dependent feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-28powerpc: ppc4xx: convert AMCC boards to generic boardAnatolij Gustschin
Add CONFIG_SYS_GENERIC_BOARD to amcc-common.h and CONFIG_DISPLAY_BOARDINFO to Kconfig files. canyonlands.h includes amcc-common.h, so remove CONFIG_SYS_GENERIC_BOARD definition there. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Feng Kan <fkan@amcc.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tom Rini <trini@konsulko.com>
2015-02-12ppc: amcc: Omit unneeded ns16550 CONFIG if using driver modelSimon Glass
This comes from the device tree or a call to get_uart_clock(). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-07ppc4xx: Remove 4xx NAND booting supportStefan Roese
As ppc4xx currently only supports the deprecated nand_spl infrastructure and nobody seems to have time / resources to port this over to the newer SPL infrastructure, lets remove NAND booting completely. This should not affect the "normal", non NAND-booting ppc4xx platforms that are currently supported. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-05-01amcc-common.h: enable support for "env grep", "setexpr", and regex.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2013-05-01amcc-common.h: minor white space cleanupWolfgang Denk
Align some comments. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2010-10-20ppc4xx: Fix default environment for AMCC boardsStefan Roese
Commit 0ad7f0950a9bc0a69b3cd5f34ccf7da25fcf1c6d [ppc4xx: cleanup default environment for AMCC boards] broke the default env for many PPC4xx boards. The '\0' character got removed at the end of some environment commands like "update". This patch adds the missing '\0' characters again. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-20ppc4xx: Enable NOR flash support in sequoia_ramboot targetStefan Roese
Until now, the Sequoia RAM-booting image disabled NOR flash support as this image was mainly created for NAND-only boards. This patch now enables NOR flash support for this RAM-booting version as well. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-08-09ppc4xx: cleanup default environment for AMCC boardsWolfgang Denk
None of the AMCC boards uses an embedded environment, so there is no need to run "saveenv" after updating U-Boot. Drop the redundant commands from the default environment. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Update flash size in reg property of the NOR flash nodeStefan Roese
Till now only the ranges in the ebc node are updated with the values currently configured in the PPC4xx EBC controller. With this patch now the NOR flash size is updated in the device tree blob as well. This is done by scanning the compatible nodes "cfi-flash" and "jedec-flash" for the correct chip select number. This size fixup is enabled for all AMCC eval board right now. Other 4xx boards may want to enable it as well, if this problem with multiple NOR FLASH sizes exists. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2009-09-10amcc-common.h: Use filenames from environment variables for update procedure.Detlev Zundel
Using a separate "u-boot" environment variable allows to easily specify different filenames for the update procedure. This is also in line with many other board configurations defining an "update" script. Signed-off-by: Detlev Zundel <dzu@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30ppc4xx: amcc: Move "kernel_addr_r" etc to higher locations (> 16MB)Stefan Roese
This patch moves the load addresses for kernel, fdt and ramdisk to higher addresses (>= 16MB). This enables booting of bigger kernel images (e.g. lockdep enabled). Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30ppc4xx: amcc: Set CONFIG_SYS_BOOTMAPSZ to 16MB for big kernelsStefan Roese
This patch changes CONFIG_SYS_BOOTMAPSZ from 8MB to 16MB which is the initial TLB on 40x PPC's in the Linux kernel. With this change even bigger Linux kernels (> 8MB) can be booted. This patch also sets CONFIG_SYS_BOOTM_LEN to 16MB (default 8MB) to enable decompression of bigger images. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12ppc4xx: Add Sequoia RAM-booting targetStefan Roese
This patch adds another build target for the AMCC Sequoia PPC440EPx eval board. This RAM-booting version is targeted for boards without NOR FLASH (NAND booting) which need a possibility to initially program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000) configured to setup the SDRAM, this debugger can load this RAM- booting image to the target address in SDRAM (in this case 0x1000000) and start it there. Then U-Boot's standard NAND commands can be used to program the NAND FLASH (e.g. "nand write ..."). Here the commands to load and start this image from the BDI2000: 440EPX>reset halt 440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin 440EPX>go 0x1000000 Please note that this image automatically scans for an already initialized SDRAM TLB (detected by EPN=0). This TLB will not be cleared. This TLB doesn't need to be TLB #0, this RAM-booting version will detect it and preserve it. So booting via BDI2000 will work and booting with a complete different TLB init via U-Boot works as well. Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-06ppc4xx: Unify AMCC's board config files (part 1/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
