path: root/include/configs/am3517_evm.h
2012-02-12am3517evm: remove rootfstype kernel parameter for MMC boot deviceYegor Yefremov
it is not necessary to define rootfstype for mass storage devices. Kernel detects it automatically. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2012-01-26nand_spl_simple: store ecc data on the stackStefano Babic
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06AM3517: Add SPL supportTom Rini
The only change of note is that we move from 0x80008000 to 0x80100000 for CONFIG_SYS_TEXT_BASE Cc: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-04am3517evm: Use generic MMC driverVaibhav Hiremath
Switch from the legacy mmc driver to the new generic mmc driver. This patch is based on similar patch for beagle[1]. [1] http://git.denx.de/?p=u-boot.git;a=commitdiff_plain;h=0cd31144240 Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-07-18am3517evm: change console device from ttyS2 to ttyO2Yegor Yefremov
the serial device names have been changed from ttySx to ttyOx, so the console device name should be also changed to support the latest kernel versions. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Acked-by: Vaibhav Hiremath<hvaibhav@ti.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-27ARMV7: OMAP3: Cleanup extern variables in mem.cLuca Ceresoli
Removed boot_flash_* extern variables. boot_flash_type was totally unused. The other ones were actually constants, so they have been replaced with #defines in the board config files. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-29AM3517:Build FIX: undef CONFIG_CMD_NFS supportVaibhav Hiremath
Without CONFIG_CMD_NET support CONFIG_CMD_NFS leads to linking error, so disable CONFIG_CMD_NFS option. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-29AM3517:Fix for ARM Relocation supportVaibhav Hiremath
Also change the CONFIG_SYS_TEXT_BASE to 0x80008000, required with relocation support. This is the load address for primary boot loader (x-loader). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-12AM3517EVM: musb: add usb configAjay Kumar Gupta
Enabling USB HOST in defconfig. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for EMIF4Vaibhav Hiremath
This patch adds support for the EMIF4 interface available in the AM35x processors. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08AM35x: Add support for AM3517EVMVaibhav Hiremath
This patch adds basic support for the AM3517EVM. It includes: - Board files (.c and .h) - Default configuration file - Updates for Makefile Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
