CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Move this option to Kconfig and tidy up existing uses.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Some armv7 targets are missing a cache line size declaration.
In preparation for "arm: cache: Implement cache range check for v7"
patch, add these declarations with the appropriate value for
the target's SoC or CPU.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
USB-related options are usually prefixed with CONFIG_USB and platform-specific
adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so
this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for
consistency.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Add CONFIG_SYS_GENERIC_BOARD to board's config header.
Boot-tested on am3517_evm board.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Enable the OMAP3 specific errata code for 454179, 430973, 621766
and while at it, remove legacy non-revision checked errata logic.
Signed-off-by: Nishanth Menon <nm@ti.com>
Tested-by: Matt Porter <mporter@konsulko.com>
This is in preperation of using generic cross OMAP code.
Currently in some cases SDRAM init requires global_data to be available
and soon this will not be available prior to board_init_f(). Adjust the
code paths in these cases to be correct. In some cases we had the SPL
stack be in DDR as we might have large stacks (due to Falcon Mode +
Environment). In these cases switch to CONFIG_SPL_STACK_R. In other
cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these
cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also
in SRAM) so drop those lines.
Tested on Beagleboard, Beagleboard xM
Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard
Tested-by: Tom Rini <trini@konsulko.com>
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config
options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR.
In addition, it is not related to raw mode booting but to fs mode instead.
Reviewed-by: Tom Rini <trini@ti.com>
Rename some defines containing FAT in their name to be filesystem generic:
MMCSD_MODE_FAT => MMCSD_MODE_FS
CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Tom Rini <trini@ti.com>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP3 board select menu to omap3/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap3
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
PISMO_xx macros were used to define 'Platform Independent Storage MOdule'
related GPMC configurations. This patch
- Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided
by current u-boot infrastructure.
- Removes unused redundant macros, which are no longer required after
merging of common platform code in following commit
commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
ARM: omap: merge GPMC initialization code for all platform
| Macro | Reason for removal |
| PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE |
| PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE |
| PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE |
| PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so |
| | configuring GPMC chip-select for smallest allowable |
| | segment (GPMC_SIZE_16M) is enough. |
| PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of |
| | 128MB (GPMC_SIZE_128M) |
| PISMO1_NOR | Unused Macros |
| PISMO1_NAND | |
| PISMO2_CS0 | |
| PISMO2_CS1 | |
| PISMO1_ONENAND | |
| PISMO2_NAND_CS0 | |
| PISMO2_NAND_CS1 | |
| PISMO1_NOR_BASE | |
| PISMO1_NAND_BASE| |
| PISMO2_CS0_BASE | |
Signed-off-by: Pekon Gupta <pekon@ti.com>
bus-width
GPMC controller needs to be configured based on bus-width of the NAND device
connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI
parameters is not possible in following situations:
SPL: SPL NAND drivers does not support ONFI parameter reading.
U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init()
which is called before probing for devices, hence any ONFI parameter
information is not available during GPMC initialization.
Thus, OMAP NAND driver expected board developers to explicitely write GPMC
configurations specific to NAND device attached on board in board files itself.
But this was troublesome for board manufacturers as they need to dive into
lengthy platform & SoC documents to find details of GPMC registers and
appropriate configurations to get NAND device working.
This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config
hich indicates that connected NAND device has x16 bus-width. And then based on
this config GPMC driver itself initializes itself based on NAND bus-width. This
keeps board developers free from knowing GPMC controller specific internals.
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI
params or nand_id[] table. And based on that it defines ECC layout.
This patch
1) removes following board configs used for defining NAND ECC layout
- GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND)
- GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND)
- GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND)
- GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND)
2) removes unused #defines in common omap_gpmc.h depending on above configs
Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed
CONFIG_xx used for selecting NAND ecc-schemes.
This patch aims at solving following issues.
1) Currently ecc-scheme is tied to SoC platform, which prevents user to select
other ecc-schemes also supported in hardware. like;
- most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite
the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with
software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW).
- most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware
supports BCH16 ecc-scheme also.
2) Different platforms use different CONFIG_xx to select ecc-schemes, which
adds confusion for user while migrating platforms.
- *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only
8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW)
whereas ELM hardware engine supports other ecc-schemes also like; BCH4,
and BCH16 (in future).
- *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error
correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW).
- *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library
Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency
on SoC platform and NAND driver. And user can select ecc-scheme independently
foreach board.
However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still
depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand)
- add omap24xx driver to new multibus/multiadpater support
- adapted all config files, which uses this driver
Tested on the am335x based siemens boards rut, dxr2 and pxm2
posted here:
http://patchwork.ozlabs.org/patch/263211/
Tested-by: Tom Rini <trini@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Tom Rix <Tom.Rix@windriver.com>
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Luca Ceresoli <luca.ceresoli@comelit.it>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Michael Jones <michael.jones@matrix-vision.de>
Cc: Raphael Assenat <raph@8d.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Adding a new CONFIG_OMAP_COMMON which is included by all boards
that needs to build cpu/armv7/omap-common folder.
[trini: Fixup common/cmd_io.c]
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere
outside of config files.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Some small SPLs do not use nand_base.c, and a subset of those also
require a special driver. Some SPLs need software ECC but others can't
fit it.
All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these
symbols added to preserve existing behavior.
v2: use positive logic for including bits of NAND, rather than
a MINIMAL symbol that excludes things.
Fix usage of 'mmc rescan' by many configs. Proper use is
'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan
the device. 'mmc rescan' itself does not take any arguments.
Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
