path: root/include/configs/am335x_evm.h
2015-06-15am335x_evm: nand: Fix boot from NANDRoger Quadros
Use the correct partition names from with the Device Tree blob and the kernel is picked up. Also use partition name instead of number for the root filesystem in the kernel boot arguments. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-15am335x_evm: am44xx_evm: dra7xx_evm: nand: Fix file-system partition nameRoger Quadros
We almost always use UBIFS for user accessible NAND file systems and the UBIFS file system might contain more than one volume within the single NAND partition. The last NAND partition is therefore more appropriately named as "NAND.file-system" instead of "NAND.rootfs" The Linux kernel (as of v3.16) also uses "NAND.file-system" to name the last NAND partition. This patch makes the partition name consistent between u-boot and the kernel. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-08ti: am335x/am437x/omap5 devices: Unify network environment variablesCooper Jr., Franklin
Across several devices network environment variables are duplicated. Move these variables to a common include file which insures the environment variables are reused and insures devices across product lines share the same values. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13am335x_evm_usbspl: Remove other SPL modesTom Rini
The purpose of this build target is to do SPL over USB RNDIS. We remove YMODEM, MMC and NAND (and re-set ENV to be built-in) as when those are needed we can use the other build targets. This brings us well under size limit again. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-02-02Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2015-01-29lib/rsa: Modify rsa to use DM driverRuchika Gupta
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library. CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29am335x_evm: Enable CONFIG_NAND_OMAP_GPMC_PREFETCHTom Rini
2015-01-05TI: armv7: enable UUID and PARTNishanth Menon
Enable UUID and partition support for scripted handling platforms with MMC and eMMC and varied partitioning schemes And remove it from headers that end up redefining it. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-11-05Enable Android Fastboot support on am335x_evm boardDileep Katta
Signed-off-by: Dileep Katta <dileep.katta@linaro.org> [trini: Rework so that am335x_evm_usbspl still builds] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-23am335x_evm: Correct "raw" portions of DFU alt intoTom Rini
2014-10-10am335x_evm: Correct BOOTCOUNT driver supportTom Rini
We need to set the 'BE' flag here for things to work right. Signed-off-by: Tom Rini <trini@ti.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-09-24spl: replace CONFIG_SPL_SPI_* with CONFIG_SF_DEFAULT_*Nikita Kiryanov
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in SPL. These #defines do not allow the user to select SPI mode for the SPI flash (there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in spi_spl_load.c), and duplicate information already provided by CONFIG_SF_DEFAULT_* #defines. Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead. Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Hannes Petermaier <hannes.petermaier@br-automation.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-09-17am335x_evm: Add boot script support to am335x_evmGuillaume GARDET
This patch adds boot script support to am335x_evm Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-25board/ti/am335x: update configs for parallel NANDpekon gupta
This patch - consolidate CONFIG_SYS_NAND_xx and CONFIG_SPL_NAND_xx from various configuration files into single file. - update MTD Partition table to match AM335x_EVM DT in linux-kernel - segregate CONFIGs based on different boot modes (like SPL and U-Boot) Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-08-25am335x_evm: Enable CONFIG_SPL_ENV_SUPPORT on EMMC_BOOTTom Rini
When we're using EMMC_BOOT that means we have environment on eMMC so we can make use of CONFIG_SPL_ENV_SUPPORT within Falcon Mode. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25am335x_evm: Move SPL network definesTom Rini
On am335x_evm we only support USBETH for a networking SPL option so move the rest of the defines under that area as that's the only time we need (and want) environment support here. Signed-off-by: Tom Rini <trini@ti.com>
2014-07-28Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-25ARM: omap: move board specific NAND configs out from ti_armv7_common.hpekon gupta
This patch moves some board specific NAND configs: - FROM: generic config file 'ti_armv7_common.h' - TO: individual board config files using these configs. So that each board can independently set the value as per its design. Following configs are affected in this patch: CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand> CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon> CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon> CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon> This patch also updates documentation for few of above NAND configs. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-25ARM: omap: fix GPMC address-map size for NAND and NOR devicespekon gupta
Fixes commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform 1) NAND device are not directly memory-mapped to CPU address-space, they are indirectly accessed via following GPMC registers: - GPMC_NAND_COMMAND_x - GPMC_NAND_ADDRESS_x - GPMC_NAND_DATA_x Therefore from CPU's point of view, NAND address-map can be limited to just above register addresses. But GPMC chip-select address-map can be configured in granularity of 16MB only. So this patch uses GPMC_SIZE_16M for all NAND devices. 2) NOR device are directly memory-mapped to CPU address-space, so its address-map size depends on actual addressable region in NOR FLASH device. So this patch uses CONFIG_SYS_FLASH_SIZE to derive GPMC chip-select address-map size configuration. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-22am335x_evm: handle import of environments in files with CRLF as line endingsAlexander Holler
Use the new option -r for env import. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2014-06-19am335x_evm: Only enable OF_CONTROL/OF_SEPARATE on VBOOT for nowTom Rini
We don't make use of the device tree otherwise yet (and will need to think how to not break the current multi-board support) and this causes further breakage with additional changes. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-11am33xx/omap: Add a new board to enable verified bootSimon Glass
Enable verified boot functionality for a new am335x_boneblack_vboot target. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11am33xx/omap: Enable FIT supportSimon Glass
Enable booting a FIT containing a kernel/device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11am33xx/omap: Enable CONFIG_OF_CONTROLSimon Glass
Add support for device tree control and add device tree files for the beaglebone black initially. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-05-05am335x: dfu: disable DFU in am335x_evm SPL buildMateusz Zalega
Future patches will make DFU too large to fit in this board's SPL build. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Tom Rini <trini@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2014-05-05dfu: mmc: change offset base handlingMateusz Zalega
Previously offsets handled by dfu_fill_entity_mmc(), defined in boards' CONFIG_DFU_ALT were treated as hexadecimal regardless of their prefix, which sometimes led to confusion. This patch forces usage of explicit numerical base prefixes. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Tom Rini <trini@ti.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-04-17am335x_evm: Drop SPI SPL support from the default buildTom Rini
This is only useful with the _spiboot build target anyhow, so only include it then. Drop CONFIG_SPL_OS_BOOT support then as the flash is small and didn't include a spot for the device tree already. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-17am335x_evm: Update the ramdisk args, we pass things in just fine via DTTom Rini
2014-04-17TI: Add, use a DEFAULT_LINUX_BOOT_ENV environment stringTom Rini
To deal with a reoccurring problem properly we need to specify addresses for the Linux kernel, Flatted Device Tree and ramdisk that obey the constraints within the kernel's Documentation/arm/Booting file but also make sure that we relocate things within a valid address range. It is possible with these addresses to also set fdt_high and initrd_high to the value of 0xffffffff. We don't do this by default to allow for the most likely success of people using custom addresses however. Signed-off-by: Tom Rini <trini@ti.com>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-03-28am335x_evm: Drop CONFIG_SPL_ETH_SUPPORT from default buildTom Rini
On the boards this target supports this option is either non possible without hardware mods (Beaglebone White/Black) or not supported due to board design. Drop this and regain some space. Signed-off-by: Tom Rini <trini@ti.com>
2014-03-12am335x_evm: Remove SPI SPL from NOR support targetTom Rini
When using the am335x_evm_nor target one is generally expecting to be used in an environment when you want to program the NOR and not a "deployment" type target. In addition this only supports the Beaglebone White with the memory cape and NOR module installed, which precludes the presence of SPI flash. Drop SPI as we were getting close to the binary limit in some cases and slightly over with other toolchains. Signed-off-by: Tom Rini <trini@ti.com>
2014-03-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21am335x_evm: Enable GPT commandsTom Rini
2014-02-21am335x: Initial support for Silica Pengwyn boardLothar Felten
This patch add support for the Silica Pengwyn board [1] The board is based on a TI AM3354 CPU [2] All jumpers removed it will boot from the SDcard, the console is on UART1 accessible via the FDTI -> USB. The on board NAND flash is supported and can act as boot medium, depending on jumper settings. USB Host, USB Device and Ethernet are also provided but untested. [1] http://www.silica.com/product/silica-pengwyn-board.html [2] http://www.ti.com/product/am3354 Signed-off-by: Lothar Felten <lothar.felten@gmail.com> [trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused spi0_pin_mux from Pengwyn support] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-12am335x_evm: Consolidate DFU environment parts into the DFU part of the fileTom Rini
To make managing the environment easier, add DFUARGS to CONFIG_EXTRA_ENV_SETTINGS. Then we set DFUARGS down in the DFU part of the file, and include (or not) the NAND part, based on if NAND is set. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-04am335x_evm: Update nandboot to use partitions and DTTom Rini
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-11-21mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-schemepekon gupta
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues. 1) Currently ecc-scheme is tied to SoC platform, which prevents user to select other ecc-schemes also supported in hardware. like; - most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW). - most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware supports BCH16 ecc-scheme also. 2) Different platforms use different CONFIG_xx to select ecc-schemes, which adds confusion for user while migrating platforms. - *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only 8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like; BCH4, and BCH16 (in future). - *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW). - *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency on SoC platform and NAND driver. And user can select ecc-scheme independently foreach board. However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand) Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-21mtd: nand: omap: make am33xx/elm.c as common driver for all OMAPx and AMxxxx ↵pekon gupta
platforms ELM hardware engine which is used for ECC error detection, is present on all latest OMAP SoC (like OMAP4xxx, OMAP5xxx, DRA7xxx, AM33xx, AM43xx). Thus ELM driver should be moved to common drivers/mtd/nand/ folder so that all SoC having on-chip ELM hardware engine can re-use it. This patch has following changes: - mv arch/arm/include/asm/arch-am33xx/elm.h arch/arm/include/asm/omap_elm.h - mv arch/arm/cpu/armv7/am33xx/elm.c drivers/mtd/nand/omap_elm.c - update Makefiles - update #include <asm/elm.h> - add CONFIG_NAND_OMAP_ELM to compile driver/mtd/nand/omap_elm.c and include in all board configs using AM33xx SoC platform. Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-11am33xx: Make SoC bootcount driver have its own symbolTom Rini
Some am33xx boards may not use the RTC block for bootcount (as it may not be wired up for the board) and use some other facility. So add another symbol for the bootcount driver for the IP block. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-10-14am335x_evm.h: Make 'am335x_boneblack' use redundant environmentTom Rini
