path: root/include/configs/alt.h
2018-09-15sh: tmu: Clean up CONFIG_SH_TMU_CLK_FREQMarek Vasut
The R-Car Gen2 feeds the TMU with CONFIG_SYS_CLK_FREQ / 2, while the old SH parts use CONFIG_SYS_CLK_FREQ directly. Just put this into the TMU implementation and drop the CONFIG_SH_TMU_CLK_FREQ config option. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-09-15sh: tmu: Clean up CONFIG_SYS_TMU_CLK_DIVMarek Vasut
This constant is always 4 , for all boards that exist. Define it once in arch/sh/lib/time.c and remove it from the configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-05-02ARM: rmobile: Zap #undef DEBUGMarek Vasut
The DEBUG macro is never defined unless explicitly enabled. Drop useless #undef DEBUG in the board configs so it won't spread any further. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-02ARM: rmobile: Convert CONFIG_ARCH_RMOBILE_BOARD_STRING to KconfigMarek Vasut
Convert the symbol to Kconfig, no functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-26ARM: rmobile: Update E2 AltMarek Vasut
The E2 Alt port was broken since some time. This patch updates the E2 Alt port to use modern frameworks, DM, DT probing, SPL for the preloading and puts it on par with the M2 Porter board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-21mmc: sh_mmcif: Migrate configs to CONFIG_SH_MMCIFMarek Vasut
Migrate the U-Boot configs to Kconfig CONFIG_SH_MMCIF . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Jaehoon Chung <jh80.chung@samsung.com>
2018-02-13spi: Migrate CONFIG_SH_QSPI to KconfigTuomas Tynkkynen
2018-01-24ARM: rmobile: Convert CONFIG_R8A77xx to KconfigMarek Vasut
Convert these configuration options to Kconfig, update board defconfigs and drop them from whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-02-25arm: rmobile: alt: Add support SDHINobuhiro Iwamatsu
Alt board has two SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Alt board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-10arm: rmobile: alt: Add support MMC and MMC commandNobuhiro Iwamatsu
Alt board has been connected to eMMC of 8GB to MMC port. This enables MMC port and MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-12-05arm: rmobile: rcar: Stop clock prior to booting kernelNobuhiro Iwamatsu
This stops clock except INTC-RT, MSIF, INTC-SYS, IRQC and SCIF before kernel boots. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-17arm: rmobile: replacement of common parts of config by rcar-gen2-common.hNobuhiro Iwamatsu
Common part of config for lager, koelsch, alt and gose board will be able to replace rcar-gen2-common.h. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Change clock of SCIF to external clockNobuhiro Iwamatsu
Change clock of SCIF for Alt board is used to external clock. This changes to using external clock. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: Move sh-i2c of the address defined to common headerNobuhiro Iwamatsu
R-Car SoCs of rmobile have same IP of sh-i2c, and have same address. This moves sh-i2c of the address defined to rcar-base.h as common header of R-Car SoCs, and headers of each SoCs. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-10arm: rmobile: alt: Remove board_late_init functionNobuhiro Iwamatsu
Alt board does not use board_late_init function. This removes this function and define of BOARD_LATE_INIT from config. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: alt: Add VFAT filesystem supportNobuhiro Iwamatsu
2014-11-04arm: rmobile: alt: Add support USB and USB commandsNobuhiro Iwamatsu
This adds support for USB commands and USB storage device. Signed-off-by: Yoshiyuki Ito <yoshiyuki.ito.ub@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-11-04arm: rmobile: alt: Add external RAM bootNobuhiro Iwamatsu
If CONFIG_RMOBILE_EXTRAM_BOOT is enabled, U-Boot is booted from External RAM. The default boot address is 0x70000000. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-07-24arm: rmobile: Add support Alt boardNobuhiro Iwamatsu
The alt board has R8A7794, 1GB DDR3-SDRAM, USB, Ethernet, QSPI, MMC, SDHI and more. This commit supports the following functions: - DDR3-SDRAM - SCIF - I2C - Ethernet - QSPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
