path: root/include/configs/ads5121.h
2008-09-18ADS5121: fix typo in "rootpath" default settingWolfgang Denk
2008-08-28ADS5121: Fix NOR and CPLD ALE timing for rev 2 siliconJohn Rigby
MPC5121 rev 2 silicon has a new register for controlling how long CS is asserted after deassertion of ALE in multiplexed mode. The default is to assert CS together with ALE. The alternative is to assert CS (ALEN+1)*LPC_CLK clocks after deassertion of ALE. The default is wrong for the NOR flash and CPLD on the ADS5121. This patch turns on the alternative for CS0 (NOR) and CS2 (CPLD) it does so conditionally based on silicon rev 2.0 or greater. Signed-off-by: Martha J Marx <mmarx@silicontkx.com> Signed-off-by: John Rigby <jrigby@freescale.com>
2008-08-26ADS5121: adjust image addresses in RAM and flashWolfgang Denk
Use the same mapping in flash as used by Linux Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-05mpc5121: squash some fdt fixup errorsJohn Rigby
On ADS5121 when booting linux the following errors are seen: Unable to update property /soc5121@80000000:bus-frequency, err=FDT_ERR_NOTFOUND Unable to update property /soc5121@80000000/ethernet@2800:local-mac-address, err=FDT_ERR_NOTFOUND Unable to update property /soc5121@80000000/ethernet@2800:address, err=FDT_ERR_NOTFOUND This is caused by ft_cpu_setup trying to deal with both old and new soc node naming. This patch fixes this by being smarter about what to fixup. Also do soc node fixups by compatible instead of by path. A new board config called OF_SOC_COMPAT defined to be "fsl,mpc5121-immr" replaces the old OF_SOC node path that was defined to be "soc@80000000". Old device trees still work, but the compatiblity is conditional on CONFIG_OF_SUPPORT_OLD_DEVICE_TREES which is on by default in include/configs/ads5121.h. Signed-off-by: John Rigby <jrigby@freescale.com>
2008-07-10Configuration changes for ADS5121 Rev 3Martha Marx
ADS5121 Rev 3 board is now the default config config targets are now ads5121_config Rev 3 board with PCI M41T62 on board RTC 512MB DRAM ads5121_rev2_config Rev 2 board with No PCI 256MB DRAM Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-07-10Consolidate ADS5121 IO Pin configurationMartha Marx
Consolidate ADS5121 IO Pin configuration to one file board/ads5121/iopin.c. Remove pin config from cpu/mpc512x/fec.c Signed-off-by: Martha Marx <mmarx@silicontkx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: John Rigby <jrigby@freescale.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-21Adding DIU support for Freescale 5121ADSYork Sun
Add DIU and cfb console support to FSL 5121ADS board. Use #define CONFIG_VIDEO in config file to enable fb console. Signed-off-by: York Sun <yorksun@freescale.com>
2008-04-25Realining some header definitions.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03ADS5121: Fix default environment.Wolfgang Denk
2008-03-02MPC5121e ADS PCI support take 3John Rigby
Adds PCI support for MPC5121 Tested with drivers/net/rtl8139.c Support is conditional since PCI on old silicon does not work. ads5121_PCI_config turns on PCI In this version, condition compilation of PCI code has been moved from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as suggested by Jean-Christophe PLAGNIOL-VILLARD Signed-off-by: John Rigby <jrigby@freescale.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2008-02-07ADS5121e: DDR2 init/timing update.Grzegorz Bernacki
Signed-off-by: John Rigby <jrigby@freescale.com> Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2008-02-07Device tree updatesJohn Rigby
Changes to match 5121 device tree going mainline in 2.6.25. Change OF_SOC from "soc5121" to plain "soc". Remove unneeded "ref-frequency" fixups. Remove "address" enetaddr fixup. Add bus-frequency fixup for old OF_SOC so old kernels with old device trees will work with new u-boot with 66MHz IPS clock Signed-off-by: John Rigby <jrigby@freescale.com>
2008-01-15ADS5121: disable watchdog; enable image timestampsWolfgang Denk
2008-01-13ADS5121: Fix typo in ads5121.c, adjust default environmentWolfgang Denk
2008-01-12ads5121: Added support for FDT.Grzegorz Bernacki
2007-12-06ADS5121 Board: fix compile problem.Wolfgang Denk
2007-10-13Coding Style cleanup.Wolfgang Denk
2007-10-09[ads5121] EEPROM support added.Grzegorz Bernacki
2007-08-12Adjust default configuration of ADS5121 board.Wolfgang Denk
2007-08-02Coding style cleanup, update CHANGELOGWolfgang Denk
2007-07-27[ADS5121] Support for the ADS5121 boardRafal Jaworowski
The following MPC5121e subsystems are supported: - low-level CPU init - NOR Boot Flash (common CFI driver) - DDR SDRAM - FEC - I2C - Watchdog Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Jan Wrobel <wrr@semihalf.com>
