path: root/include/configs/adp-ag102.h
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-22board/adp-ag102: add configuration of adp-ag102Macpaul Lin
board: Add config file of board adp-ag102 Add adp-ag102 into boards.cfg Add adp-ag102 into MAINTAINERS doc: add README of ag102 Signed-off-by: Macpaul Lin <macpaul@andestech.com>
