path: root/include/configs/adp-ag101.h
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-24nds32: Enable the function of passing parameters to Linuxken kuo
Add a header file, setup.h, which copy from Linux source code, this file contain structures are used to pass initialisation parameters to Linux. Enable this function on adp-ag101/adp-ag101p target Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: Enable SDIO and EXT2 command support for Andes boardken kuo
2013-07-24nds32: Enable two banks of SDRAM on Andes boardken kuo
The original adp-ag101/adp-ag101p initialize only one bank(64MB) by default at boot time, but it is not enough for some application, so increasing to two banks(128M). Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-10-22adp-ag101: add board adp-ag101 supportMacpaul Lin
Add evaluation board "adp-ag101" configuration file adp-ag101.h. Add adp-ag101.c board config and related settings. Add board adp-ag101 into boards.cfg Signed-off-by: Macpaul Lin <macpaul@andestech.com>
