path: root/include/configs/actux4.h
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-26IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST}Marek Vasut
These symbols are no longer defined in Linux-ARM's mach-types files. Replace these with CONFIG_MACH_TYPE instead. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2011-06-23update/fix AcTux4 boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-01-31ixp: move serial to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-01-31ixp: remove the option to include the MicrocodeJean-Christophe PLAGNIOL-VILLARD
instead the board will have to load it from flash or ram which will be specified by npe_ucode env var Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-18add AcTux-4 board supportMichael Schwingen
