rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
This patch series unifies the AMCC eval board ports by introducing
a common include header for all AMCC eval boards:
include/configs/amcc-common.h
This header now includes all common configuration options/defines which
are removed from the board specific headers.
The reason for this is ease of maintenance and unified look and feel
of all AMCC boards.
This patch adds fdt (flattened device tree) support to the AMCC
Acadia eval board. This increases the image size and it doesn't
fit anymore into 256kByte. Since we didn't want to remove features
from the configuration, we decided to increase the U-Boot image size
(add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
All 4xx board config files don't need the cache definitions anymore.
These are now defined in common headers.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
The latest changes showed a problem with the location of the NAND-SPL
image in the OCM and the init-data area (incl. cache). This patch
fixes this problem.
This patch adds NAND booting support for the AMCC Acadia eval board.
Please make sure to configure jumper J7 to position 2-3 when booting
from NOR, and to position 1-2 when booting for NAND.
I also added a board command to configure the I2C bootstrap EEPROM
values. Right now only 267MHz is support for booting either via NOR
or NAND FLASH. Here the usage:
=> bootstrap 267 nor ;to configure the board for 267MHz NOR booting
=> bootstrap 267 nand ;to configure the board for 267MHz NNAND booting
This patch updates the Acadia (405EZ) support for the new 1.1 board
revision. It also adds support for NAND FLASH via the 4xx NDFC.
Please note that the jumper J7 must be in position 2-3 for this
NAND support. Position 1-2 is for NAND booting only. NAND booting
support will follow later.
This patch cleans up all the open issue of the preliminary
Acadia support.
This patch adds support for the new AMCC Acadia eval board.
Please note that this Acadia/405EZ support is still in a beta stage.
Still lot's of cleanup needed but we need a preliminary release now.
