path: root/include/configs/a320evb.h
2011-11-29arm: a320evb: define mach-type in board config fileYan-Pai Chen
MACH_TYPE_FARADAY was dropped from mach-types.h. Add it back to board config file. Signed-off-by: Yan-Pai Chen <ypchen@faraday-tech.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2011-08-04arm: a320: enable tagged list supportPo-Yu Chuang
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-08-04arm: a320: fix multiline comment stylePo-Yu Chuang
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-28arm: a320: fix compile error caused by commit 00d10ebPo-Yu Chuang
2011-04-27ftsmc020: move ftsmc020 static mem controller to driver/mtdMacpaul Lin
Move the header file and definitions of ftsmc020 static memory control unit from a320 SoC folder to "drivers/mtd" folder. This change will let other SoC which also use ftsmc020 could share the same header file. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-27arm: a320: use new ftpmu010 APIPo-Yu Chuang
ftpmu010 related code has been moved to drivers/power/. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2011-02-02arm: a320evb: fixes for relocation supportPo-Yu Chuang
* add CONFIG_SYS_SDRAM_BASE and CONFIG_SYS_INIT_SP_ADDR * do not update gd->bd in dram_init() because bd is unavailable then * move CONFIG_SYS_TEXT_BASE from config.mk to a320evb.h * remove config.mk Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2009-11-27arm: A320: Add support for Faraday A320 evaluation boardPo-Yu Chuang
This patch adds support for A320 evaluation board from Faraday. This board uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM. FA526 is an ARMv4 processor and uses the ARM920T source in this patch. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
