path: root/include/configs/ZPC1900.h
2011-10-17powerpc: cpm2 boards: update fcc register logicMike Frysinger
In the recent dropping of !NET_MULTI code (commit e2a53458a7ab37523304), I misread the logic in include/net.h. Some of it was used by NET_MULTI code as glue between the multi/non-multi worlds for cpm2 boards. Rather than restore the block of code, push the logic to the board config headers where it all belongs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-10Update all board to support new bbmiiphy driver (with multibus support)Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various [TUVWZYZ]* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2006-03-12Memory configuration changes for ZPC.1900 boardWolfgang Denk
- Fix SDRAM timing on both local bus and 60x bus - Add support for second flash bank (SIMM) - Change boot flash base Patch by Yuli Barcohen, 05 Jun 2005
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-10-09Patch by Yuli Barcohen, 22 Aug 2004:wdenk
- remove ZPC.1900 board-specific flash driver; switch the port to generic CFI driver; - port clean-up
2004-06-09Patch by Robert Schwebel, 13 May 2004:wdenk
Add 'imgextract' command: extract one part of a multi file image.
2004-03-25Code cleanupLABEL_2004_03_25_1630wdenk
2003-10-08* Patch by Yuli Barcohen, 25 Sep 2003:wdenk
add support for Zephyr Engineering ZPC.1900 board * Patch by Anders Larsen, 23 Sep 2003: add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only implemented for the x86 architecture)
