path: root/include/configs/XPEDITE5170.h
2010-07-20powerpc/86xx: Move PCI/PCIe address defines into common immap_86xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Renamed CONFIG_SYS_PCI1/2_ADDR to CONFIG_SYS_PCI1/2ADDR on MPC8641 boards since its really PCIE controllers and not PCI. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-24ppc/85xx: Fix LCRR_CLKDIV definesKumar Gala
For some reason the CLKDIV field varies between SoC in how it interprets the bit values. All 83xx and early (e500v1) PQ3 devices support: clk/2: CLKDIV = 2 clk/4: CLKDIV = 4 clk/8: CLKDIV = 8 Newer PQ3 (e500v2) and MPC86xx support: clk/4: CLKDIV = 2 clk/8: CLKDIV = 4 clk/16: CLKDIV = 8 Ensure that the MPC86xx and MPC85xx still get the same behavior and make the defines reflect their logical view (not the value of the field). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-22xes: Increase CONFIG_SYS_BOOTM_LEN to 16MBPeter Tyser
Increasing CONFIG_SYS_BOOTM_LEN from 8 MB to 16 MB is necessary to support uncompressing images larger than 8 MB when using the bootm command. Note that recent Linux kernels for the 85xx and 86xx map greater than 16MB of memory on bootup, but we use 16MB to maintain compatibility with older Linux kernels for now. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-20Remove last remanants of unused CONFIG_I2C_CMD_TREEPeter Tyser
2009-07-0186xx: XPedite5170 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5170 - a MPC8640-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
