path: root/include/configs/XPEDITE1K.h
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-03-23* Patch by Stephen Williams, 19 March 2004wdenk
Increase speed of sector reads from SystemACE, shorten poll timeout and remove a useless reset * Patch by Tolunay Orkun, 19 Mar 2004: Make GigE PHY 1000Mbps Speed/Duplex detection conditional (CONFIG_PHY_GIGE) * Patch by Brad Kemp, 18 Mar 2004: prevent machine checks during a PCI scan * Patch by Pierre Aubert, 18 Mar 2004: Fix string cleaning in IDE identification
2004-02-27* Patch by Travis Sawyer, 26 Feb 2004:wdenk
Fix broken compile for XPEDITE1K target. * Patch by Stephan Linz, 26 Feb 2004: Bug fix for NFS code on NIOS targets * Patch by Stephen Williams, 26 Feb 2004: Break up SystemACE reads of large block counts
2004-02-22* Patch by Travis Sawyer, 09 Feb 2004:wdenk
o 440GX: - Fix PCI Indirect access for type 1 config cycles with ppc440. - Add phymode for 440 enet - fix pci pre init o XPedite1K: - Change board_pre_init to board_early_init_f - Add user flash to bus controller setup - Fix pci pre init - Fix is_pci_host to check GPIO for monarch bit - Force xpedite1k to pci conventional mode (via #define option) * Patch by Brad Kemp, 4 Feb 2004: - handle the machine check that is generated during the PCI scans on 82xx processors. - define the registers used in the IMMR by the PCI subsystem. * Patch by Pierre Aubert, 03 Feb 2004: cpu/mpc5xxx/start.S: copy MBAR into SPR311 * Patch by Jeff Angielski, 03 Feb 2004: Fix copy & paste error in cpu/mpc8260/pci.c * Patch by Reinhard Meyer, 24 Jan 2004: Fix typo in cpu/mpc5xxx/pci_mpc5200.c
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
