CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Freescale (NXP) boards have lots of defconfig files per board.
I used "imply PANIC_HANG" for them.
Reviewed-by: York Sun <york.sun@nxp.com>
This symbol enables some library code used by various SATA drivers,
so make this a non-user-visible symbol select'ed by the respective
drivers, and let moveconfig handle the rest.
Use 'imply' here liberally to avoid the combinatorial explosion of
defconfig changes in the PowerPC boards.
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be
equal to CONFIG_SYS_CBSIZE in numerous configuration files.
We remove such definitions in two situations:
- CONFIG_SYS_CBSIZE is otherwise not defined in the board
configuration file, which means the default value of
CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is
larger.
- CONFIG_SYS_CBSIZE is defined in the board configuration file, but
to a value equal or less than 512. In this case, the default value
of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it
is equal or larger.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Now that include/config_fallbacks.h define a sane fallback for
CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all
configurations that were using the default value.
Now that the fallback value of CONFIG_SYS_PBSIZE in
include/config_fallbacks.h has been adjusted, remove its definition
from a large number of board configuration files.
CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all
[trini: Drop <config.h> from stih410-b2260.h]
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
This patch converts CONFIG_CMD_REGINFO to Kconfig
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_CMD_PCI
CONFIG_CMD_MMC_SPI
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
These boards will now use the ksz90x1 driver instead of the mess in
ksz8xxx. This change is needed before the two drivers can be fully
separated.
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_ENV_IS_IN_FLASH
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_SATA
There is some inconsistency between uses of CONFIG_RTC_DS13xx and
CONFIG_SYS_RTC_DS13xx. Address this by dropping the "SYS" from
these variables.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_CMD_IRQ
CONFIG_CMD_ERRATA
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
[trini: default y if DM_RTC, re-sync]
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
configs/ls1046aqds_defconfig
configs/ls1046aqds_nand_defconfig
configs/ls1046aqds_qspi_defconfig
configs/ls1046aqds_sdcard_ifc_defconfig
configs/ls1046aqds_sdcard_qspi_defconfig
configs/ls1046ardb_emmc_defconfig
configs/ls1046ardb_qspi_defconfig
configs/ls1046ardb_sdcard_defconfig
Enable ELBC from Kconfig.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC.
Let's create an entry for "config GENERIC_MMC" with "default MMC",
then convert all macro defines in headers to Kconfig. Almost all
of the defines will go away.
I see only two exceptions:
configs/blanche_defconfig
configs/sandbox_noblk_defconfig
They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something
might be wrong with these two boards, so should be checked later.
Anyway, this is the output of the moveconfig tool.
This commit was created as follows:
[1] create a config entry in drivers/mmc/Kconfig
[2] tools/moveconfig.py -r HEAD GENERIC_MMC
[3] manual clean-up of garbage comments in doc/README.* and
include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
Use option NUM_DDR_CONTROLLERS in ddr Kconfig and clean up existing
usage in ls102xa and fsl-layerscape. Remove all powerpc macros in
config header and board header files.
Signed-off-by: York Sun <york.sun@nxp.com>
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
Use Kconfig option for E500 and E500MC macros.
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Some header files have this macro defined conditionally and
redefined unconditionally. Remove all existing definitions.
Replace CONFIG_P1020 with ARCH_P1020 in Kconfig and clean up
existing macros.
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
Reviewed-by: Jagan Teki <jteki@openedev.com>
[trini: Re-migrate, update common/console.c logic]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
