path: root/include/configs/Total5200.h
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05Fixing some typos etc. introduced mainly by cfg patches.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in various 5200 board config files.Jon Loeliger
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-08-04* Patch by Martin Krause, 03 Aug 2004:wdenk
change timing for SM501 graphics controller on TQM5200 module * Patch by Mark Jonas, 13 July 2004: - Total5200 LCD now run in little endian mode. Endianess conversion is done in hardware. - Removed last reference to "console" environment variable.
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11* Cleanupwdenk
* Patch by Mark Jonas, 05 Jul 2004: add support for the Total5100's and Total5200's LCD screen * Patches by Dan Eisenhut, 01 Jul 2004: - README fixes. - Move doc2000.h include to prevent compiler warning on some boards
2004-07-11Patch by Mark Jonas, 01 Jul 2004:wdenk
Added support for Total5100 and Total5200 (Rev.1 and Rev.2) MGT5100 and MPC5200 based Freescale platforms.
