2004-04-24 | Clean up the TQM8xx_YYMHz configurations; allow to use the same | wdenk | |
binary image for all clock frequencies. Implement run-time optimization of flash access timing based on the actual bus frequency. | |||
2003-08-07 | Update for TQM board defaults:U-Boot-0_4_5 | wdenk | |
disable clocks_in_mhz, enable boot count limit | |||
2003-07-07 | * Add support for NSCU boardU-Boot-0_4_2 | wdenk | |
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules |
