There was for long time no activity in the 8xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 8xx,
so remove it (with a heavy heart, knowing that I remove
here the root of U-Boot).
CONFIG_CMD_JFFS2
CONFIG_CMD_IDE
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
This converts all TQM8xx boards (MPC8xx based) to generic board.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
[trini: Fixup common/cmd_io.c]
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created
ide_init_postreset() (invoked after calling ide_reset after ide_preinit),
some cleanup to make checkpatch happy, enable IDE init hooks in configs of
affected boards.
confusingly, these hooks are used by more than just mpc8xx-based boards, and
therefore are placed in arch/ppc/lib/
note: checkpatch still emits warnings about using volatile
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names
with spaces drop a
Warning: eth device name has a space!
message. This patch fix it for:
- "FEC ETHERNET" devices found on
mpc512x, mpc5xxx, mpc8xx and mpc8220 boards.
renamed to "FEC".
- "SCC ETHERNET" devices found on
mpc8xx, mpc82xx based boards. Renamed to "SCC".
- "HDLC ETHERNET" devices found on mpc8xx boards
Renamed to "HDLC"
- "FCC ETHERNET" devices found on mpc8260 and mpc85xx based
boards. Renamed to "FCC"
Tested on the kup4k board.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
Commit 2b3f12c2 added support for configurable SMC Rx buffer length on
8xx systems. Enable this feature on TQM8xx* based boards.
This fixes the problem that pasting text in the middle of a line
(i. e. inserting in edit mode) did not work - only the first two
characters got inserted, the rest was lost.
By changing the cmd_mtdparts to only use the MTD infrastructure and
not the direct interface to the CFI NOR FLASH driver we now need
to add the MTD infrastructure to all boards using those mtdparts
commands. This patch adds those components:
CONFIG_MTD_DEVICE (for all FLASH types)
plus
CONFIG_FLASH_CFI_MTD (for NOR FLASH)
To all board maintainers: Please test this on your platforms and
report any problems/issues found. Thanks.
Cc: Ron Madrid <info@sheldoninst.com>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Martin Krause <martin.krause@tqs.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
- enable CFI driver where this was forgotten
- enable mtdparts support
- adjust default environment
etc.
When switching the TQM8xxL modules to use the CFI flash driver,
support for the second flash bank was broken because the CFI driver
did not support dynamically sized banks. This gets fixed now.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
With recent toolchains, the environment sectors were no longer aligned to
sector boundaries. The reason was a combination of two bugs:
1) common/environment.c assumed that CONFIG_TQM8xxL would be defined
for all TQM8xxL and TQM8xxM boards. But "include/common.h", where
this gets defined, is not included here (and cannot be included
without causing lots of problems).
Added a new #define CFG_USE_PPCENV for all boards which really
want to put the environment is a ".ppcenv" section.
2) The linker scripts just include environment.o, silently assuming
that the objects in that file are really in the order in which
they are coded in the C file, i. e. "environment" first, then
"redundand_environment", and "env_size" last. However, current
toolchains (GCC-4.x) reorder the objects, causing the environment
data not to start on a flash sector boundary:
Instead of: we got:
40008000 T environment 40008000 T env_size
4000c000 T redundand_environment 40008004 T redundand_environment
40010000 T env_size 4000c004 T environment
Note: this patch fixes just the first part, and cures the alignment
problem by making sure that "env_size" gets placed correctly. However,
we still have a potential issue because primary and redundant
environment sectors are actually swapped, i. e. we have now:
40008000 T redundand_environment
4000c000 T environment
40010000 T env_size
This shall be fixed in the next version.
CONFIG_BOOTP_MASK.
