All 85xx boards have been converted to the new code so we can
remove the old SPD DDR setup code.
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
Some TQM85xx boards could be equipped with up to 1 GiB (NOR) Flash
memory. The current memory map only supports up to 128 MiB Flash.
This patch adds the configuration option CONFIG_TQM_BIGFLASH. If
set, up to 1 GiB flash is supported. To achieve this, the memory
map has to be adjusted in great parts (for example the CCSRBAR is
moved from 0xE0000000 to 0xA0000000).
If you want to boot Linux with CONFIG_TQM_BIGFLASH set, the new
memory map also has to be considered in the kernel (changed
CCSRBAR address, changed PCI IO base address, ...). Please use
an appropriate Flat Device Tree blob (tqm8548.dtb).
Signed-off-by: Martin Krause <martin.krause@tqs.de>
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This patch adds support for NAND FLASH on the TQM8548. It is disabled by
default and can be enabled for the TQM8548 modules. It is now based on
the re-written FSL NAND UPM driver. A patch has been posted earlier today
with the subject:
"NAND FSL UPM: driver re-write using the hwcontrol callback"
Note that the R/B pin is not supported by that module requiring to use
the specified maximum delay time.
Note: With NAND support enabled the size of the U-Boot image exceeds
256 KB and TEXT_BASE must therefore be set to 0xfff80000 in config.mk,
doubling the image size :-(.
Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de>
This patch adds support for PCI express cards. The board support
now uses common FSL PCI init code, for both, PCI and PCIe on all
TQM85xx modules.
This patch adds basic support for the TQM8548 module from TQ-Components
(http://www.tqc.de/) including DDR2 SDRAM initialisation and support for
eTSEC 3 and 4
Furthermore Flash buffer write has been enabled to speed up output to
the Flash by approx. a factor of 10.
This patch adds support for Linux kernels using the Flat Device Tree.
It also re-defines the default environment settings for booting Linux
with the FDT blob.
This patch adds initialization of the UPMC RAM to support up to two
Intel 82527 compatible CAN controller on the TQM85xx modules.
The 'N' type Spansion flashes (S29GLxxxN series) have bigger sectors,
than the formerly used 'M' types (S29GLxxxM series), so the flash layout
needs to be changed -> new start address of the environment. The macro
definition CONFIG_TQM_FLASH_N_TYPE is undefined by default and must be
defined for boards with 'N' type flashes.
When we go to 36-bit physical addresses we need to keep the concept of
the physical CCSRBAR address seperate from the virtual one.
For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR
The latter version stops when "run load" fails for whatever reasons
rendering the combination *a lot* more secure.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Now that all boards have been converted, remove old config code and the
config option for the new style.
Converted ATUM8548, MPC8568 MDS, MPC8540 EVAL, and TQM85xx boards over
to use new LAW init code.
Either use the standard defines in asm/cache.h or grab the information
at runtime from the L1CFG SPR.
Also, minor cleanup in cache.h to make the code a bit more readable.
/bin/bash and /bin/dash (which /bin/sh is linked to on ubuntu) handle embedded
nulls in a string differently. For example, the following statement:
echo "this is a string\0" > afile
Will produce the following with /bin/bash:
But with /bin/dash, will produce:
"this is a string
Bug fixed by moving the embedded null out of the makefile and into the
config header. Also renamed the macro to avoid usage colision with the same
macro used by other board ports.
platforms wishing to display RAM diagnostics in addition to size,
can do so, on one line, in their own board_add_ram_info()
implementation.
this consequently eliminates CONFIG_ADD_RAM_INFO.
Thanks to Stefan for the hint.
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether
to update TSEC1's device-tree node, so we need to add it
to all the boards with TSECs. Do this for 83xx and 86xx, too,
since they will eventually do something similar.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The tsec_info structure and array has a "flags" field for each
ethernet controller. This field is the only reason there are
settings. Switch to defining TSECn_FLAGS for each controller
in the config header, and we can greatly simplify the array, and
also simplify the addition of future boards.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
For all practical u-boot purposes, TSECs don't differ throughout the
mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx.
Introduced COFIG_FSL_I2C to select the common FSL I2C driver.
And removed hard i2c path from a few u-boot.lds scipts too.
Minor whitespace cleanups along the way.
The PS/2 keyobard driver for the TQM85xx modules only supports the
internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't
include a DUART, the TQM8560 modules can't be used with the PS/2
keyboard controller on the STK85xx board.
The PS/2 keyboard driver should work with the modules TQM8540,
TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet.
Make sure the PS/2 controller on the STK85xx is programmed. Jumper
settings: X66 1-2, 9-10; X61 2-3
Patch by Martin Krause, 21 Jun 2006
Patch by Martin Krause, 07 Nov 2005
Tested on a STK85XX baseboard. Make sure the PS/2 controller
has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
- Support for TQM8541/8555 boards added.
- Complete rework of TQM8540/8560 support.
- Common TQM85xx code now supports all current TQM85xx platforms
(TQM8540/8541/8555/8560).
- DDR SDRAM size detection added.
- CAS latency default values can be overwritten by setting "serial#"
to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used.
If problems are detected with this non default CAS latency,
the defualt values will be used instead.
- FLASH size detection added.
- Moved FCC ethernet driver initialization behind TSEC driver init
-> TSEC is first device.
Patch by Stefan Roese, 30 Nov 2005
