path: root/include/configs/TQM85xx.h
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-08-11Fix preboot message on TQM85xx after switching to hush parser.Wolfgang Denk
2006-08-11Adapt TQM85xx ramdisk address to Linux kernel memory mapWolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2006-07-19Fix support for PS/2 keyboard on TQM85xx boardsWolfgang Denk
The PS/2 keyobard driver for the TQM85xx modules only supports the internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't include a DUART, the TQM8560 modules can't be used with the PS/2 keyboard controller on the STK85xx board. The PS/2 keyboard driver should work with the modules TQM8540, TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet. Make sure the PS/2 controller on the STK85xx is programmed. Jumper settings: X66 1-2, 9-10; X61 2-3 Patch by Martin Krause, 21 Jun 2006
2006-06-16Add support for PS/2 keyboard on TQM85xx boardWolfgang Denk
Patch by Martin Krause, 07 Nov 2005 Tested on a STK85XX baseboard. Make sure the PS/2 controller has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
2005-11-30Add support for TQM8541/8555 boards, TQM85xx support reworked:Stefan Roese
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005
