path: root/include/configs/TQM855M.h
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-04-24Clean up the TQM8xx_YYMHz configurations; allow to use the samewdenk
binary image for all clock frequencies. Implement run-time optimization of flash access timing based on the actual bus frequency.
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-08-07Update for TQM board defaults:U-Boot-0_4_5wdenk
disable clocks_in_mhz, enable boot count limit
2003-07-07* Add support for NSCU boardU-Boot-0_4_2wdenk
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules
