path: root/include/configs/TQM855M.h
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-03-12TQM8xx: enable device tree support on all TQM8xx based boards.Heiko Schocher
Also enable support for CONFIG_HWCONFIG because we use this for configuring if this hardware has a FEC or not. syntax: hwconfig=fec:on if hardware has an fec hwconfig=fec:off if hardware has no fec Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-28TQM8xx* boards: set larger SMC Rx buffer lenWolfgang Denk
Commit 2b3f12c2 added support for configurable SMC Rx buffer length on 8xx systems. Enable this feature on TQM8xx* based boards. This fixes the problem that pasting text in the middle of a line (i. e. inserting in edit mode) did not work - only the first two characters got inserted, the rest was lost. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-21Enable ext2 support for TQM8xxL/M based boardsWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-12Coding style cleanup, update CHANGELOG, prepare releasev1.3.4Wolfgang Denk
2008-08-09TQM8xx{L,M}: try to normalize config files for TQM8xx? based boardWolfgang Denk
- enable CFI driver where this was forgotten - enable mtdparts support - adjust default environment etc. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-12-27TQM8xx: use the CFI flash driver on all TQM8xx boardsMartin Krause
Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-09-16TQM8xx[LM]: Fix broken environment alignment.Wolfgang Denk
With recent toolchains, the environment sectors were no longer aligned to sector boundaries. The reason was a combination of two bugs: 1) common/environment.c assumed that CONFIG_TQM8xxL would be defined for all TQM8xxL and TQM8xxM boards. But "include/common.h", where this gets defined, is not included here (and cannot be included without causing lots of problems). Added a new #define CFG_USE_PPCENV for all boards which really want to put the environment is a ".ppcenv" section. 2) The linker scripts just include environment.o, silently assuming that the objects in that file are really in the order in which they are coded in the C file, i. e. "environment" first, then "redundand_environment", and "env_size" last. However, current toolchains (GCC-4.x) reorder the objects, causing the environment data not to start on a flash sector boundary: Instead of: we got: 40008000 T environment 40008000 T env_size 4000c000 T redundand_environment 40008004 T redundand_environment 40010000 T env_size 4000c004 T environment Note: this patch fixes just the first part, and cures the alignment problem by making sure that "env_size" gets placed correctly. However, we still have a potential issue because primary and redundant environment sectors are actually swapped, i. e. we have now: 40008000 T redundand_environment 4000c000 T environment 40010000 T env_size This shall be fixed in the next version. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-09-16TQM8xx/FPS8xx: adjust flash partitions for 2.6 ARCH=powerpc kernelsWolfgang Denk
2007-07-09include/configs/[T-Z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-04-24Clean up the TQM8xx_YYMHz configurations; allow to use the samewdenk
binary image for all clock frequencies. Implement run-time optimization of flash access timing based on the actual bus frequency.
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-08-07Update for TQM board defaults:U-Boot-0_4_5wdenk
disable clocks_in_mhz, enable boot count limit
2003-07-07* Add support for NSCU boardU-Boot-0_4_2wdenk
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules
