Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names
with spaces drop a
Warning: eth device name has a space!
message. This patch fix it for:
- "FEC ETHERNET" devices found on
mpc512x, mpc5xxx, mpc8xx and mpc8220 boards.
renamed to "FEC".
- "SCC ETHERNET" devices found on
mpc8xx, mpc82xx based boards. Renamed to "SCC".
- "HDLC ETHERNET" devices found on mpc8xx boards
Renamed to "HDLC"
- "FCC ETHERNET" devices found on mpc8260 and mpc85xx based
boards. Renamed to "FCC"
Tested on the kup4k board.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
Commit 2b3f12c2 added support for configurable SMC Rx buffer length on
8xx systems. Enable this feature on TQM8xx* based boards.
This fixes the problem that pasting text in the middle of a line
(i. e. inserting in edit mode) did not work - only the first two
characters got inserted, the rest was lost.
By changing the cmd_mtdparts to only use the MTD infrastructure and
not the direct interface to the CFI NOR FLASH driver we now need
to add the MTD infrastructure to all boards using those mtdparts
commands. This patch adds those components:
CONFIG_MTD_DEVICE (for all FLASH types)
plus
CONFIG_FLASH_CFI_MTD (for NOR FLASH)
To all board maintainers: Please test this on your platforms and
report any problems/issues found. Thanks.
Cc: Ron Madrid <info@sheldoninst.com>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Martin Krause <martin.krause@tqs.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
- enable CFI driver where this was forgotten
- enable mtdparts support
- adjust default environment
etc.
When switching the TQM8xxL modules to use the CFI flash driver,
support for the second flash bank was broken because the CFI driver
did not support dynamically sized banks. This gets fixed now.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
With recent toolchains, the environment sectors were no longer aligned to
sector boundaries. The reason was a combination of two bugs:
1) common/environment.c assumed that CONFIG_TQM8xxL would be defined
for all TQM8xxL and TQM8xxM boards. But "include/common.h", where
this gets defined, is not included here (and cannot be included
without causing lots of problems).
Added a new #define CFG_USE_PPCENV for all boards which really
want to put the environment is a ".ppcenv" section.
2) The linker scripts just include environment.o, silently assuming
that the objects in that file are really in the order in which
they are coded in the C file, i. e. "environment" first, then
"redundand_environment", and "env_size" last. However, current
toolchains (GCC-4.x) reorder the objects, causing the environment
data not to start on a flash sector boundary:
Instead of: we got:
40008000 T environment 40008000 T env_size
4000c000 T redundand_environment 40008004 T redundand_environment
40010000 T env_size 4000c004 T environment
Note: this patch fixes just the first part, and cures the alignment
problem by making sure that "env_size" gets placed correctly. However,
we still have a potential issue because primary and redundant
environment sectors are actually swapped, i. e. we have now:
40008000 T redundand_environment
4000c000 T environment
40010000 T env_size
This shall be fixed in the next version.
CONFIG_BOOTP_MASK.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
enable SNTP support in some boards.
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
disable clocks_in_mhz, enable boot count limit
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
* Add support for LXT971 PHY on PM826
* Patch by Tord Andersson, 16 Jan 2003:
Fix flash sector count for TQM8xxL
* Fix I2C EEPROM problem on ICU862 board (would only write the first
16 bytes out of each 32 byte block)
Add i2c commands to PM826 config
* extend I2C POST code: check for list on known addresses
