We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
This converts all TQM8xx boards (MPC8xx based) to generic board.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
[trini: Fixup common/cmd_io.c]
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created
ide_init_postreset() (invoked after calling ide_reset after ide_preinit),
some cleanup to make checkpatch happy, enable IDE init hooks in configs of
affected boards.
confusingly, these hooks are used by more than just mpc8xx-based boards, and
therefore are placed in arch/ppc/lib/
note: checkpatch still emits warnings about using volatile
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
This also fixes a build warning:
main.c: In function 'main_loop':
main.c:311:16: warning: variable 'bootlimit' set but not used
[-Wunused-but-set-variable]
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
Commit 2b3f12c2 added support for configurable SMC Rx buffer length on
8xx systems. Enable this feature on TQM8xx* based boards.
This fixes the problem that pasting text in the middle of a line
(i. e. inserting in edit mode) did not work - only the first two
characters got inserted, the rest was lost.
By changing the cmd_mtdparts to only use the MTD infrastructure and
not the direct interface to the CFI NOR FLASH driver we now need
to add the MTD infrastructure to all boards using those mtdparts
commands. This patch adds those components:
CONFIG_MTD_DEVICE (for all FLASH types)
plus
CONFIG_FLASH_CFI_MTD (for NOR FLASH)
To all board maintainers: Please test this on your platforms and
report any problems/issues found. Thanks.
Cc: Ron Madrid <info@sheldoninst.com>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Martin Krause <martin.krause@tqs.de>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
- enable CFI driver where this was forgotten
- enable mtdparts support
- adjust default environment
etc.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
With recent toolchains, the environment sectors were no longer aligned to
sector boundaries. The reason was a combination of two bugs:
1) common/environment.c assumed that CONFIG_TQM8xxL would be defined
for all TQM8xxL and TQM8xxM boards. But "include/common.h", where
this gets defined, is not included here (and cannot be included
without causing lots of problems).
Added a new #define CFG_USE_PPCENV for all boards which really
want to put the environment is a ".ppcenv" section.
2) The linker scripts just include environment.o, silently assuming
that the objects in that file are really in the order in which
they are coded in the C file, i. e. "environment" first, then
"redundand_environment", and "env_size" last. However, current
toolchains (GCC-4.x) reorder the objects, causing the environment
data not to start on a flash sector boundary:
Instead of: we got:
40008000 T environment 40008000 T env_size
4000c000 T redundand_environment 40008004 T redundand_environment
40010000 T env_size 4000c004 T environment
Note: this patch fixes just the first part, and cures the alignment
problem by making sure that "env_size" gets placed correctly. However,
we still have a potential issue because primary and redundant
environment sectors are actually swapped, i. e. we have now:
40008000 T redundand_environment
4000c000 T environment
40010000 T env_size
This shall be fixed in the next version.
CONFIG_BOOTP_MASK.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
enable SNTP support in some boards.
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
disable clocks_in_mhz, enable boot count limit
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
