path: root/include/configs/TQM850M.h
2007-07-09include/configs/[T-Z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-04-24Clean up the TQM8xx_YYMHz configurations; allow to use the samewdenk
binary image for all clock frequencies. Implement run-time optimization of flash access timing based on the actual bus frequency.
2003-08-07Update for TQM board defaults:U-Boot-0_4_5wdenk
disable clocks_in_mhz, enable boot count limit
2003-07-07* Add support for NSCU boardU-Boot-0_4_2wdenk
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules * Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML mirror bit flash on TQM8xxM modules
