path: root/include/configs/TQM834x.h
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-14TQM834x: clean up configurationWolfgang Denk
Get board name consistent with Linux and elsewhere; get rid of local network definitions etc. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-29TQM834x: enable DHCPJens Gehrlein
Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-29TQM834x: support for Spansion N-type Flashes (sector size = 256 KiB at 2x16 ↵Jens Gehrlein
Bit). Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: Remove cache config from config.hDave Liu
clean up the cache config from configs.h of board Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-10TQM834x: cleanup configuratonMartin Krause
Remove irritating #undef DEBUG Signed-off-by: Martin Krause <martin.krause@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Fix config of Arbiter, System Priority, and Clock ModeKumar Gala
The config value for: * CFG_ACR_PIPE_DEP * CFG_ACR_RPTCNT * CFG_SPCR_TSEC1EP * CFG_SPCR_TSEC2EP * CFG_SCCR_TSEC1CM * CFG_SCCR_TSEC2CM Were not being used when setting the appropriate register Added: * CFG_SCCR_USBMPHCM * CFG_SCCR_USBDRCM * CFG_SCCR_PCICM * CFG_SCCR_ENCCM To allow full config of the SCCR. Also removed random CFG_SCCR settings in MPC8349EMDS, TQM834x, and sbc8349 that were just bogus. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Fix dual I2C support for the MPC8349ITX, MPC8349EMDS, TQM834x, and ↵Timur Tabi
MPC8360EMDS This patch also adds an improved I2C set_speed(), which handles all clock frequencies. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: fix TQM build by defining a CFG_FLASH_SIZE for itTimur Tabi
2006-11-03mpc83xx: Unified TQM834x variable names with 83xx and consolidated macrosTanya Jiang
Unified TQM834x variable names with 83xx and consolidated macro in preparation for the 8360 and other upcoming 83xx devices. Signed-off-by: Tanya Jiang <tanya.jiang@freescale.com>
2006-10-28Enable commandline editing and hush shell on all TQM boards.Wolfgang Denk
2006-08-18Fix TQM834x hang.Rafal Jaworowski
2006-02-10Enable address translation on MPC83xxKumar Gala
Patch by Kumar Gala, 10 Feb 2006
2006-01-11Make System IO Config Registers board configurable on MPC83xxKumar Gala
Patch by Kumar Gala, 11 Jan 2006
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-12-01Adjust TQM834x PHY addresses for latest hardware revision.Wolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-12Fix TQM834x config file, set correct value for CFG_IMMRBAR.Marian Balakowicz
2005-10-11Added support for TQM834x boards.Marian Balakowicz
