path: root/include/configs/TQM834x.h
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-04-22mpc83xx: turn on icache in core initialization to improve u-boot boot timeKim Phillips
before, MPC8349ITX boots u-boot in 4.3sec: column1 is elapsed time since first message column2 is elapsed time since previous message column3 is the message 0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX 0.000 0.000: 0.000 0.000: Reset Status: 0.000 0.000: 0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.032 0.000: Board: Freescale MPC8349E-mITX 0.032 0.000: UPMA: Configured for compact flash 0.032 0.000: I2C: ready 0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 1.516 1.456: FLASH: 16 MB 2.641 1.125: PCI: Bus Dev VenId DevId Class Int 2.652 0.011: 00 10 1095 3114 0180 00 2.652 0.000: PCI: Bus Dev VenId DevId Class Int 2.652 0.000: In: serial 2.652 0.000: Out: serial 2.652 0.000: Err: serial 2.682 0.030: Board revision: 1.0 (PCF8475A) 3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic 3.080 0.000: TSEC0, TSEC1 4.300 1.219: IDE: Bus 0: .** Timeout ** after, MPC8349ITX boots u-boot in 3.0sec: 0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX 0.010 0.000: 0.010 0.000: Reset Status: 0.010 0.000: 0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.017 0.000: Board: Freescale MPC8349E-mITX 0.038 0.020: UPMA: Configured for compact flash 0.038 0.000: I2C: ready 0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 0.260 0.222: FLASH: 16 MB 1.390 1.130: PCI: Bus Dev VenId DevId Class Int 1.390 0.000: 00 10 1095 3114 0180 00 1.390 0.000: PCI: Bus Dev VenId DevId Class Int 1.400 0.010: In: serial 1.400 0.000: Out: serial 1.400 0.000: Err: serial 1.400 0.000: Board revision: 1.0 (PCF8475A) 1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic 1.832 0.000: TSEC0, TSEC1 3.038 1.205: IDE: Bus 0: .** Timeout ** also tested on these boards (albeit with a less accurate boottime measurement method): seconds: before after 8349MDS ~2.6 ~2.2 8360MDS ~2.8 ~2.6 8313RDB ~2.5 ~2.3 #nand boot 837xRDB ~3.1 ~2.3 also tested on an 8323ERDB. v2: also remove the delayed icache enablement assumption in arch ppc's board.c, and add a CONFIG_MPC83xx define in the ITX config file for consistency (even though it was already being defined in 83xx' config.mk). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-22mpc83xx: enable command line autocompletionKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-26mpc83xx: retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfieldsKim Phillips
some LCRR bits are not documented throughout the 83xx family RMs. New board porters copying similar board configurations might omit setting e.g., DBYP since it was not documented in their SoC's RM. Prevent them bricking their board by retaining power on reset values in bit fields that the board porter doesn't explicitly configure via CONFIG_SYS_<registername>_<bitfield> assignments in the board config file. also move LCRR assignment to cpu_init_r[am] to help ensure no transactions are being executed via the local bus while CLKDIV is being modified. also start to use i/o accessors. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-08-21mpc83xx: tqm8349 - remove pci & flash window conflictKim Phillips
commit 9993e196da707a0a1cd4584f1fcef12382c1c144 "mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCI" remapped pci windows on tqm834x to make it more consistent with the other 83xx boards. During that time however, the author failed to realize that FLASH_BASE was occupying the same range as what PCI1_MEM_BASE was being assigned. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Tested-by: Wolfgang Denk <wd@denx.de>
2009-07-27mpc83xx: CONFIG_83XX_GENERIC_PCI is now synonymous with CONFIG_PCI; remove ↵Kim Phillips
the former Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-18mpc83xx: convert all remaining boards over to 83XX_GENERIC_PCIKim Phillips
2009-06-1283xx: Replace CONFIG_MPC83[0-9]X with MPC83[0-9]xPeter Tyser
Use the standard lowercase "x" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-06-12TQM834x: use buffered writes to accelerate writing to flashWolfgang Denk
Also enable display of 'E'mpty sectors in "flinfo" output. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12TQM834x: add FDT supportWolfgang Denk
2009-06-12TQM834x: fix environment size; add redundant env.Wolfgang Denk
Also reserve more space for U-Boot as it will probably grow soon. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-08mpc83xx: don't set SICRH_TSOBI1 to RMII/RTBI operationKim Phillips
In GMII mode (which operates at 3.3V) both SICRH TSEC1/2 output buffer impedance bits should be clear, i.e., SICRH[TSIOB1] = 0 and SICRH[TSIOB2] = 0. SICRH[TSIOB1] was erroneously being set high. U-Boot always operated this PHY interface in GMII mode. It is assumed this was missed in the clean up by the original board porters, and copied along to the TQM and sbc boards. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Ira Snyder <iws@ovro.caltech.edu> Reviewed-by: David Hawkins <dwh@ovro.caltech.edu> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Dave Liu <DaveLiu@freescale.com>
2009-05-20TQM834x: remove defines causing gcc4.4 warningsKim Phillips
Configuring for TQM834x board... cpu_init.c: In function 'cpu_init_f': cpu_init.c:262: warning: array subscript is above array bounds cpu_init.c:263: warning: array subscript is above array bounds cpu_init.c:270: warning: array subscript is above array bounds ... Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-06-1083xx/85xx: further localbus cleanupsAnton Vorontsov
move the BRx_* and ORx_* left behind in mpc85xx.h The same is needed for mpc8xx.h and mpc8260.h (defines are almost the same, just few differences which needs some attention though). But the bad news for mpc8xx and mpc8260 is that there are a lot of users of these defines. So this cleanup I'll leave for the "better times". Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-14TQM834x: clean up configurationWolfgang Denk
Get board name consistent with Linux and elsewhere; get rid of local network definitions etc. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-29TQM834x: enable DHCPJens Gehrlein
Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-29TQM834x: support for Spansion N-type Flashes (sector size = 256 KiB at 2x16 ↵Jens Gehrlein
Bit). Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-10mpc83xx: Remove cache config from config.hDave Liu
clean up the cache config from configs.h of board Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-10TQM834x: cleanup configuratonMartin Krause
Remove irritating #undef DEBUG Signed-off-by: Martin Krause <martin.krause@tqs.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: Fix config of Arbiter, System Priority, and Clock ModeKumar Gala
The config value for: * CFG_ACR_PIPE_DEP * CFG_ACR_RPTCNT * CFG_SPCR_TSEC1EP * CFG_SPCR_TSEC2EP * CFG_SCCR_TSEC1CM * CFG_SCCR_TSEC2CM Were not being used when setting the appropriate register Added: * CFG_SCCR_USBMPHCM * CFG_SCCR_USBDRCM * CFG_SCCR_PCICM * CFG_SCCR_ENCCM To allow full config of the SCCR. Also removed random CFG_SCCR settings in MPC8349EMDS, TQM834x, and sbc8349 that were just bogus. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Fix dual I2C support for the MPC8349ITX, MPC8349EMDS, TQM834x, and ↵Timur Tabi
MPC8360EMDS This patch also adds an improved I2C set_speed(), which handles all clock frequencies. Signed-off-by: Timur Tabi <timur@freescale.com>
