path: root/include/configs/TQM5200.h
2010-12-17mpc52xx, charon: change mtd default partitionsHeiko Schocher
New default partitions on nor flash: 640k (firmware) 1408k (kernel) 2m (initrd) 4m (small-fs) 24320k (big-fs) 256k (dts) Signed-off-by: Heiko Schocher <hs@denx.de>
2010-12-17mpc5200, tqm5200: correct MTDIDS_DEFAULT to fit with name linux assignsHeiko Schocher
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-275xxx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-10-08tqm5200: Correct comment and code in post_hotkeys_pressed.Detlev Zundel
This fixes the code and the comment according to the original intent of doing an intensive memory test when PSC6_3 is pulled low on the STK52xx. Notably PORT_CONFIG will be overridden with this correct code now, so beware. The original code only worked by coincidence depending on the PORT_CONFIG setting from the header file. The new code was tested to ensure that the (undocumented) memory test still works on the STK52x. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Martin Krause <Martin.Krause@tqs.de> Minor white-space cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12mtd: MTD related config header changes (mtdparts command)Stefan Roese
By changing the cmd_mtdparts to only use the MTD infrastructure and not the direct interface to the CFI NOR FLASH driver we now need to add the MTD infrastructure to all boards using those mtdparts commands. This patch adds those components: CONFIG_MTD_DEVICE (for all FLASH types) plus CONFIG_FLASH_CFI_MTD (for NOR FLASH) To all board maintainers: Please test this on your platforms and report any problems/issues found. Thanks. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ron Madrid <info@sheldoninst.com> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Michal Simek <monstr@monstr.eu> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Martin Krause <martin.krause@tqs.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-01TQM5200: enable support for ATAPI devicesWolfgang Denk
2008-08-21Adding bootlimit/bootcount feature for MPC5XXX on TQM5200 BoardsAxel Beierlein
Tested with TQM5200S on STK52XX.200 Board Signed-off-by: Axel Beierlein <belatronix@web.de>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-19TQM5200B: update MTD partition layoutMartin Krause
- insert partition for dtb blob to TQM5200B MTD layout - set env variables dependent on the configured board (TQM5200 or TQM5200B) Signed-off-by: Martin Krause <martin.krause@tqs.de>
2008-01-09Fix problems with usb storage devices on MPC5200 /TQM5200Markus Klotzbücher
The MPC5200 OHCI controller operates in big endian, so CFG_OHCI_BE_CONTROLLER must be defined for it to work properly. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2007-10-25TQM5200: increase kernel_addr_r and fdt_addr_r (hinted by Wolfgang Denk).Bartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-10-24TQM5200: fix spurious characters on second serial interfaceMartin Krause
With this patch PSC3 is configured as UART. This is done, because if the pins of PSC3 are not configured at all (-> all pins are GPI), due to crosstalk, spurious characters may be send over the RX232_2_TXD signal line. Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-10-10Merge branch 'master' of /.automount/castor-vlab/root/home/wd/git/u-boot/master/Wolfgang Denk
2007-10-05tqm5200: Fix CONFIG_CMD_PCI typo in board config file.Marian Balakowicz
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-09-13tqm5200: Restore customary env. variable boot commands for powerpc kernelsBartlomiej Sieka
- update default definitions of kernel_addr and fdt_addr env. variables - make arch/powerpc booting the default scenario - update MTD partition layout to match the above Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08Clear up confusion over the CMD_POST and POST_DIAG mess.Jon Loeliger
For some reason, CONFIG_POST permeated as CONFIG_CMD_POST_DIAG when it really means just CONFIG_CMD_DIAG. There is no CMD_POST. Clear this mess up some. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-05include/configs: Use new CONFIG_CMD_* in TQM board config files.Jon Loeliger
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-08TQM5200: Add Flat Device Tree support, update default env. accordingly.Bartlomiej Sieka
Signed-off-by: Jan Wrobel <wrr@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-05-29Merge git://www.denx.de/git/u-boot into 2007_05_15-testingMarkus Klotzbuecher
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2007-01-10Adjusted default environment for cam5200 board.Reinhard Thies
2007-01-10CAM5200 flash driver modifications:Marian Balakowicz
- use CFI driver (replaces custom flash driver) for main 'cam5200' target - add second build target 'cam5200_niosflash' which still uses custom driver
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-11-27Modified the mpc5xxx and the ppc4xx cpu to use the generic OHCI driverMarkus Klotzbuecher
and adapted board configs TQM5200 and yosemite accordingly. This commit also makes the maximum number of root hub ports configurable (CFG_USB_OHCI_MAX_ROOT_PORTS).
2006-11-23Updates for TQM5200 modules:Wolfgang Denk
- fix off-by-one error in board/tqm5200/cam5200_flash.c error message - simplify "udate" definitions
