Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in
cmd_init.c. Add CONFIG_MII_INIT to board configuration files
that use mii_init() in cmd_init.c.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
CONFIG_BOOTP_MASK.
config files.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
Patch by Pantelis Antoniou, 04 Sep 2005
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
Add support for Motorola MPC8266ADS board
* Patch by Kyle Harris, 19 Feb 2003:
patches for the Intel lubbock board:
memsetup.S - general cleanup (based on Robert's csb226 code)
flash.c - overhaul, actually works now
lubbock.c - fix init funcs to return proper value
* Patch by Kenneth Johansson, 26 Feb 2003:
- Fixed off by one in RFTA calculation.
- No need to abort when LDF is lower than we can program it's only
minimum timing so clamp it to what we can do.
- Takes function pointer to function for reading the spd_nvram. Usefull
for faking data or hardcode a module without the nvram.
- fix other user for above change
- fix some comments.
* Patches by Brian Waite, 26 Feb 2003:
- fix port for evb64260 board
- fix PCI for evb64260 board
- fix PCI scan
* Patch by Reinhard Meyer, 1 Mar 2003:
Add support for EMK TOP860 Module
* Patch by Yuli Barcohen, 02 Mar 2003:
Add SPD EEPROM support for MPC8260ADS board
