path: root/include/configs/T4240QDS.h
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-22powerpc/ifc: fix invalid CSn FTIM2.TCH settingShaohui Xie
On some platforms, CSn FTIM2.TCH is set to zero which is invalid, an invalid hold time makes DUT timing variances, whether it works or not on luck. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16powerpc/srio-pcie-boot: Adjust addresses for SRIO/PCIE bootLiu Gang
The new 768KB u-boot image size requires changes for SRIO/PCIE boot. These addresses need to be updated to appropriate locations. The updated addresses are used to configure the SRIO/PCIE inbound windows for the boot, and they must be aligned with the window size based on the SRIO/PCIE modules requirement. So for the 768KB u-boot image, the inbound window cannot be set with 0xfff40000 base address and 0xc0000 size, it should be extended to 1MB size and the base address can be aligned with the size. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16mpc85xx: configs: remove c=ffe from default environmentKim Phillips
AFAICT, c=ffe does nothing and was a typo from the original commit d17123696c6180ac8b74fbd318bf14652623e982 "powerpc/p4080: Add support for the P4080DS board" and just kept on getting duplicated in subsequently added board config files. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Edward Swarthout <ed.swarthout@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/T4QDS: add two stage boot of nand/sdShaohui Xie
Add support of 2 stage NAND/SD boot loader using SPL framework. PBL initialise the internal SRAM and copy SPL, this further initialise DDR using SPD and environment and copy u-boot from NAND/SD to DDR, finally SPL transfer control to u-boot. NOR uses CS1 instead of CS2 when NAND boot, fix it. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-12freescale: pblimage: refactor CONFIG_SYS_FSL_PBL_{PBI, RCW}Masahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_FSL_PBL_PBI and CONFIG_SYS_FSL_PBL_RCW and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: York Sun <yorksun@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-01-22esdhc: Detecting 8 bit width before mmc initializationHaijun.Zhang
The upper 4 data signals of esdhc are shared with spi flash. So detect if the upper 4 pins are assigned to esdhc before enable sdhc 8 bit width. Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-22esdhc: Workaround for card can't be detected on T4240QDSHaijun.Zhang
Card detection pin is ineffective on T4240QDS Rev1.0. There are two cards can be connected to board. 1. eMMC card is built-in board, can not be removed. so For eMMC card it is always there. 2. Card detecting pin is functional for SDHC card in Rev2.0. This workaround force sdhc driver scan and initialize the card regardless of whether the card is inserted or not in case Rev1.0. Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc:Rename CONFIG_PBLRCW_CONFIG & CONFIG_SYS_FSL_PBL_PBIPrabhakar Kushwaha
Rename CONFIG_PBLRCW_CONFIG and CONFIG_PBLRCW_CONFIG. Also add their details in README. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-11-21mtd: move & update nand_ecclayout structure (plus board changes)Prabhakar Kushwaha
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux. Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640. Changes from Prabhabkar's version (squashed into one patch to preserve bisectability): - Added _LARGE to MTD_MAX_*_ENTRIES This makes the names match current Linux source, and resolves a conflict between http://patchwork.ozlabs.org/patch/280488/ and http://patchwork.ozlabs.org/patch/284513/ The former was posted first and is closer to matching Linux, but unlike Linux it does not add _LARGE to the names. The second adds _LARGE to one of the names, and depends on it in a subsequent patch (http://patchwork.ozlabs.org/patch/284512/). - Made max oobfree/eccpos configurable, and used this on tricorder, alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build for me without doing so, due to a size increase). On tricorder SPL, this saves 2576 bytes (and makes the SPL build again) versus the new default of 640 eccpos and 32 oobfree, and saves 336 bytes versus the old default of 128 eccpos and 8 oobfree. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Vipin Kumar <vipin.kumar@st.com> [scottwood@freescale.com: changes as described above] Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Thomas Weber <weber@corscience.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2013-10-31powerpc/esdhc: Add 3.3v voltage support in esdhc capacity registerHaijun.Zhang
T4240QDS eSDHC host capabilities reigster should have VS33 bit define. Add quirk CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 to deal with capacity missing Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-16powerpc: add CONFIG_SECURE_BOOT condition into fsl_secure_boot.hPo Liu
This patch is for board config file not to add CONFIG_SECURE_BOOT condition for include the asm/fsl_secure_boot.h. Signed-off-by: Po Liu <Po.Liu@freescale.com>
2013-08-09powerpc/rman: fix RMan support for t4240 and b4860Minghuan Lian
1. Add CONFIG_SYS_DPAA_RMAN macro to t4240 and b4860. 2. Decrease RMan liodn offset number. SET_RMAN_LIODN() is used to set liodn offset of RMan blocks 0-3. For t4240 and b4860, RMan liodn base is assigned to 922, the original offset number is too large that the liodn (base+offset 922+678 = 1600) is greater than 0x500 the maximum liodn number. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/mpc8xxx: Add memory reset controlYork Sun
JEDEC spec requires the clocks to be stable before deasserting reset signal for RDIMMs. Clocks start when any chip select is enabled and clock control register is set. This patch also adds the interface to toggle memory reset signal if needed by the boards. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/T4240EMU: Add T4240EMU targetYork Sun
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet Signed-off-by: York Sun <yorksun@freescale.com>
2013-05-14powerpc/t4240qds: Move SoC define into boards.cfgYork Sun
Separate CONFIG_PPC_T4240 from board config file. Prepare to add more SoC variants supported on the same board. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/t4qds: Add T4QDS boardYork Sun
The T4240QDS is a high-performance computing evaluation, development and test platform supporting the T4240 QorIQ Power Architecture™ processor. SERDES Connections 32 lanes grouped into four 8-lane banks Two “front side” banks dedicated to Ethernet Two “back side” banks dedicated to other protocols DDR Controllers Three independant 64-bit DDR3 controllers Supports rates up to 2133 MHz data-rate Supports two DDR3/DDR3LP UDIMM/RDIMMs per controller QIXIS System Logic FPGA Each DDR controller has two DIMM slots. The first slot of each controller has up to 4 chip selects to support single-, dual- and quad-rank DIMMs. The second slot has only 2 chip selects to support single- and dual-rank DIMMs. At any given time, up to total 4 chip selects can be used. Detail information can be found in doc/README.t4qds Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
