path: root/include/configs/T208xRDB.h
2019-06-20powerpc: mpc85xx: Move CONFIG_FSL_PCIE_RESET to KconfigHou Zhiqiang
Use the Kconfig option to select the PCIe reset errata. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14configs: Remove unneeded CONFIG_SYS_LDSCRIPT instancesTom Rini
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of the default searched LDSCRIPT paths. Remove these customizations. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-03-03configs: fsl: move DDR specific defines to KconfigRajesh Bhagat
Moves below DDR specific defines to Kconfig: CONFIG_FSL_DDR_BIST CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE CONFIG_FSL_DDR_INTERACTIVE CONFIG_FSL_DDR_SYNC_REFRESH Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-06configs: drop CONFIG_SYS_EXTRA_ENV_RELOCSimon Goldschmidt
Instead of manually specifying CONFIG_SYS_EXTRA_ENV_RELOC for every board that needs it, it shouldn't hurt to let initr_reloc_global_data() always relocate gd->env_addr unless we know this pointer is outside the initial binary. To achieve this, the relocation is omitted if CONFIG_ENV_ADDR is defined (and ENV_IS_EMBEDDED is not). Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-07-26powerpc: mpc85xx: Drop u-boot-with-spl.bin on selected boardsYork Sun
For SoCs with PBL, u-boot-with-spl-pbl.bin is the final image for SPL boot. Drop unused u-boot-with-spl.bin. Signed-off-by: York Sun <york.sun@nxp.com> CC: Ashish Kumar <ashish.kumar@nxp.com> CC: Ruchika Gupta <ruchika.gupta@nxp.com> CC: Priyanka Jain <priyanka.jain@nxp.com> CC: Shengzhou Liu <Shengzhou.Liu@nxp.com>
2018-07-24config: remove unused CONFIG_SPL_RELOC_STACK_SIZEHeinrich Schuchardt
Symbol CONFIG_SPL_RELOC_STACK_SIZE is not used anywhere. So remove it. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-14configs: Drop unused CONFIG_SPL_MMC_MINIMALTom Rini
The option CONFIG_SPL_MMC_MINIMAL is unused in code, drop it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-10configs: Move SYS_DPAA_QBMAN to KconfigAhmed Mansour
The CONFIG_SYS_DPAA_QBMAN define is used by DPAA1 freescale SOCs to add device tree fixups that allow deep sleep in Linux. The define was placed in header files included by a number of boards, but was not explicitly documented in any of the Kconfigs. A description was added to the drivers/networking menuconfig and default selection for current SOCs that have this part Signed-off-by: Ahmed Mansour <ahmed.mansour@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-12ata: Migrate CONFIG_LIBATA to KconfigTuomas Tynkkynen
This symbol enables some library code used by various SATA drivers, so make this a non-user-visible symbol select'ed by the respective drivers, and let moveconfig handle the rest. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-12-12ata: Migrate CONFIG_FSL_SATA to KconfigTuomas Tynkkynen
Use 'imply' here liberally to avoid the combinatorial explosion of defconfig changes in the PowerPC boards. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_REGINFO to KconfigChristophe Leroy
This patch converts CONFIG_CMD_REGINFO to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
