path: root/include/configs/T1040QDS.h
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-21board/T1040qds: Add VSC9953 support for T1040qds boardCodrin Ciubotariu
This patch configures and initializes the L2 switch on T1040QDS board. The L2 switch ports must be initialized according to the SerDes protocols. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
2015-01-16mpc85xx/t1040qds: convert deep sleep to generic board interfacetang yuantian
A new deep sleep interface is introduced to support generic board structure. Converts it to use new interface. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15powerpc/T10xx: Fix number of portalsJeffrey Ladouceur
Following boards has incorrect number of portals defined. powerpc/T102xQDS powerpc/T102xRDB powerpc/T1040QDS powerpc/T104xRDB Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15mpc85xx: inhibit qman and bman portals by defaultJeffrey Ladouceur
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management. Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t104x: Convert to use generic board codevijay rai
Convert T1040QDS and T1040RDB to use generic board code. Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1040qds: Update DDR optionYork Sun
Enable interactive debugging by default. Remove DDR controller interleaving because this SoC only has one controller. Use auto chip-select interleaving to detect number of ranks. Signed-off-by: York Sun <yorksun@freescale.com> CC: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2014-11-23config: remove redundant CONFIG_SYS_PROMPT definesMasahiro Yamada
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT), each board header does not need to define CONFIG_SYS_PROMPT as long as it uses the default prompt "=> ". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-16mpc85xx: configs - Enable blob command in freescale platformsRuchika Gupta
Enable blob commands for platforms having SEC 4.0 or greater for secure boot scenarios Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Add hash command in freescale platformsRuchika Gupta
Enable CAAM in platforms supporting the hardware block. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-12fsl/diu: ch7301 encoder split off from t1040qds/diu.cWang Dongsheng
The ch7301 encoder not only used in t1040qds platform, so we split it for t1042rdb and LSx platform. Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/t1040: update i2c for t1040qds and t104xrdbShengzhou Liu
- Fix base address of I2C2 as 0x118100 instead of 0x119000. - Add definitions for I2C3 & I2C4. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-06-05powerpc/mpc85xx: Add workaround to enable TDM on T1040Sandeep Singh
This is a workaround for 32 bit hardware limitation of TDM. T1040 has 36 bit physical addressing, TDM DMAC register are 32 bit wide but need to store address of CCSR space which lies beyond 32 bit address range. This workaround creats a LAW to enable access of TDM DMA to CCSR by mapping CCSR to overlap with DDR. A hole of 16M is created in memory using device tree. This workaround law is set only if "tdm" is defined in hwconfig. Also disable POST tests and add LIODN for TDM Signed-off-by: Sandeep Singh <Sandeep@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16mpc85xx: configs: remove c=ffe from default environmentKim Phillips
AFAICT, c=ffe does nothing and was a typo from the original commit d17123696c6180ac8b74fbd318bf14652623e982 "powerpc/p4080: Add support for the P4080DS board" and just kept on getting duplicated in subsequently added board config files. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Edward Swarthout <ed.swarthout@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22T1040QDS/U-QE: Add u-qe support to t1040qdsZhao Qiang
Add u-qe support for t1040qds Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx: Add deep sleep support on T1040QDSTang Yuantian
Add deep sleep support on T1040QDS platform. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/T1040: add mtdparts suppport for T104xRDB and T1040QDSPrabhakar Kushwaha
We use dynamical mtdparts partition instead of directly puting mtd partitions nodes in device tree. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx/T1040QDS_D4: Add DDR4 supportYork Sun
T1040QDS_D4 is a variant of T1040QDS, with additional circuit to support DDR4 memory. Tested with MTA9ASF51272AZ-2G1AYESZG. Signed-off-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-12freescale: pblimage: refactor CONFIG_SYS_FSL_PBL_{PBI, RCW}Masahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_FSL_PBL_PBI and CONFIG_SYS_FSL_PBL_RCW and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: York Sun <yorksun@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-03-07powerpc/t1040qds: Add Video - HDMI supportPriyanka Jain
T1040 has internal display interface unit (DIU) for driving video. T1040QDS supports video mode via -LCD using TI enconder -HDMI type interface via HDMI encoder Chrontel, CH7301C encoder which is I2C programmable is used as HDMI connector on T1040QDS. This patch add support to -enable Video interface for T1040QDS -route qixis multiplexing to enable DIU-HDMI interface on board -program DIU pixel clock gerenartor for T1040 -program HDMI encoder via I2C on board Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-19config: remove platform CONFIG_SYS_HZ definition part 3Masahiro Yamada
This commit removes platform CONFIG_SYS_HZ definition for the remainders of part1 (commit cdb23792) and part2 (commit f232950f). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <rob.herring@calxeda.com>
2014-02-03boards/t1040qds: Adds ethernet support for T1040Prabhakar Kushwaha
Enable entherent for T1040QDS. It enables FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5 Define MDIO related configs Added eth.c file Update t1040.c to support RGMII and SGMII Update t1040qds.c to support ethernet Define the PHY address Signed-off-by: Arpit Goel <B44344@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: remove dash from commit message] Signed-off-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc:Rename CONFIG_PBLRCW_CONFIG & CONFIG_SYS_FSL_PBL_PBIPrabhakar Kushwaha
Rename CONFIG_PBLRCW_CONFIG and CONFIG_PBLRCW_CONFIG. Also add their details in README. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/t1040qds: Update DDR initialization related settingsPriyanka Jain
Update following DDR related settings for T1040QDS -Correct number of chip selects to two as t1040qds supports two Chip selects. -Update board_specific_parameters udimm structure with settings derived via calibration. -Reduced I2C speed to 50KHz as DDR-SPD does not get reliably read at 400KHz. Verified the updated settings to be working fine with dual-ranked Micron, MT18KSF51272AZ-1G6 DIMM at data rate 833MT/s, 1333MT/s and 1600MT/s. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-02board/t1040qds: Enable memory reset controlPrabhakar Kushwaha
Define QIXIS_RST_FORCE_MEM to reset on-board DDR-DIMM before start accessing it. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-02board/t1040qds: Relax IFC FPGA timingsPrabhakar Kushwaha
Current IFC-FPGA TCH(Chip Select hold time with respect to WE deassertion) is 0 i.e. 0 ns hold time on writes. This may not work on higher clock freqencies. So, Increase TCH as 0x8 i.e. 8 ip_clk. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/t1040: enable PBL tool for T1040Prabhakar Kushwaha
Use a default RCW of protocol 0x66. A PBI configure file which uses CPC as 256KB SRAM. It can be used by PBL tool on T1040 to build a pbl boot image. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-10-16powerpc/t1040qds: Add T1040QDS boardPrabhakar Kushwaha
T1040QDS is a high-performance computing evaluation, development and test platform supporting the T1040 QorIQ Power Architecture™ processor. T1040QDS board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: — PCI Express: supporting Gen 1 and Gen 2; — SGMII — QSGMII — SATA 2.0 — Aurora debug with dedicated connectors - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 8-bit, async, up to 2GB. - NOR: 8-bit or 16-bit, non-multiplexed, up to 512MB - GASIC: Simple (minimal) target within Qixis FPGA - PromJET rapid memory download support - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - QIXIS System Logic FPGA - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - Video - DIU supports video at up to 1280x1024x32bpp - USB - Supports two USB 2.0 ports with integrated PHYs — Two type A ports with 5V@1.5A per port. — Second port can be converted to OTG mini-AB - SDHC - SDHC port connects directly to an adapter card slot, featuring: - Supporting SD slots for: SD, SDHC (1x, 4x, 8x) and/or MMC — Supporting eMMC memory devices - SPI - On-board support of 3 different devices and sizes - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: fix conflict in boards.cfg] Acked-by-by: York Sun <yorksun@freescale.com>
