path: root/include/configs/Sandpoint8240.h
2014-01-24powerpc: mpc824x: remove redundant CONFIG_MPC824X definitionMasahiro Yamada
We do not have to define CONFIG_MPC824X in board config headers because it is defined in arch/powerpc/cpu/mpc824x/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2010-11-27824x: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-26WINBOND_83C553: enable only on boards that actually use it.Wolfgang Denk
So far, only the BAB7xx board would call the initialise_w83c553f() function for the WINBOND 83C553 chip, even though some other boards (HIDDEN_DRAGON, Sandpoint8240, Sandpoint8245) enabled it in their board configuration. These boards were also missing other config settings needed for that, which resulted in build errors like this: drivers/pci/libpci.o:(.got2+0x84): undefined reference to `ide_bus_offset' Switch arch/powerpc/lib/board.c to call initialise_w83c553f() not on a per-board base, but when a WINBOND_83C553 in enabled in a configuration (like BAB7xx), and disable it in the boards that had this set so far. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Yusdi Santoso <yusdi_santoso@adaptec.com> Cc: Jim Thompson <jim@musenki.com> Acked-by: Stefan Roese <sr@denx.de>
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/misc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various S* named board config files.Jon Loeliger
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2003-12-27* Make CPU clock on ICA-IP board controllable by a "cpuclk"wdenk
environment variable which can set to "100", "133", or "150". The CPU clock will be configured accordingly upon next reboot. Other values are ignored. In case of an invalid or undefined "cpuclk" value, the compile-time default CPU clock speed will be used. * Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory window that is used to access the UART registers by the Linux driver) * Patch by Reinhard Meyer, 20 Dec 2003: Fix clock calculation for the MPC5200 for higher clock frequencies (above 2**32 / 10 = 429.5 MHz).
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
