path: root/include/configs/Sandpoint8240.h
2008-08-13drivers/pci: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-08-13drivers/misc: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various S* named board config files.Jon Loeliger
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2003-12-27* Make CPU clock on ICA-IP board controllable by a "cpuclk"wdenk
environment variable which can set to "100", "133", or "150". The CPU clock will be configured accordingly upon next reboot. Other values are ignored. In case of an invalid or undefined "cpuclk" value, the compile-time default CPU clock speed will be used. * Enable Quad-UART on BMS2003 board (initialize the PCMCIA memory window that is used to access the UART registers by the Linux driver) * Patch by Reinhard Meyer, 20 Dec 2003: Fix clock calculation for the MPC5200 for higher clock frequencies (above 2**32 / 10 = 429.5 MHz).
2003-09-10* Add support for USB Mass Storage Devices (BBB)wdenk
(tested with USB memory sticks only) * Avoid flicker on TRAB's VFD
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
